Mystery Misfire
HemiHog
Hi all,
Basically I am out of options here. I drive an 09 1500 5.7L Hemi. For the past month now I have had a multi cylinder misfire code. I started off by pulling the spark plugs, in doing so I found 3/16 that looked like they were BBQ'ed. While replacing those I inspected the Coils/Boots, and injectors. I replaced the damaged coil and replaced all plugs. Unfortunately the code came back on. Anyone able to help a brother out?
H
HemiHog
Swapped out with NGK O.E.M's
R/T_Fire
Pleasant Grove
This may sound funny but check your fuel pressure, you may have a failing pump that isn't delivering the right fuel, its enough to run but not perform 100%
Had a similar issue on my ZR2 turned out the fuel pressure was 5psi under spec. changed the pump and solved the problem, after I already replaced the whole ignition system
R/T_Fire
Pleasant Grove
The only other thing I can think of is a cam or crank position sensor. other than that I got nothing.
H
HemiHog
Check engine light is off now. Keeps going on and off
Same code every time? And there is no symptoms other then the CEL?
H
HemiHog
It was misfiring until I changed the plugs. Now it runs smooth, full power with CEL
So you fixed it but it might take a few days to clear. I would drive around in Tow/Haul mode and keep that MDS turned off and keep all of those cylinders firing good. Time to get a ported throttle body if it keeps up.
H
HemiHog
Ported throttle body? Lol
H
HemiHog
I was thinking to myself tonight about this issue. Could a faulty O2 sensor throw a misfire code?
Ghstrdr95
