Mystery Misfire
HemiHog
Hi all,
Basically I am out of options here. I drive an 09 1500 5.7L Hemi. For the past month now I have had a multi cylinder misfire code. I started off by pulling the spark plugs, in doing so I found 3/16 that looked like they were BBQ'ed. While replacing those I inspected the Coils/Boots, and injectors. I replaced the damaged coil and replaced all plugs. Unfortunately the code came back on. Anyone able to help a brother out?
H
HemiHog
Swapped out with NGK O.E.M's
R/T_Fire
Pleasant Grove
This may sound funny but check your fuel pressure, you may have a failing pump that isn't delivering the right fuel, its enough to run but not perform 100%
Had a similar issue on my ZR2 turned out the fuel pressure was 5psi under spec. changed the pump and solved the problem, after I already replaced the whole ignition system
R/T_Fire
Pleasant Grove
The only other thing I can think of is a cam or crank position sensor. other than that I got nothing.
H
HemiHog
Check engine light is off now. Keeps going on and off
Burla
2010 Hemi Reg Cab 4x4
Same code every time? And there is no symptoms other then the CEL?
H
HemiHog
It was misfiring until I changed the plugs. Now it runs smooth, full power with CEL
Burla
So you fixed it but it might take a few days to clear. I would drive around in Tow/Haul mode and keep that MDS turned off and keep all of those cylinders firing good. Time to get a ported throttle body if it keeps up.
H
HemiHog
Ported throttle body? Lol
H
HemiHog
I was thinking to myself tonight about this issue. Could a faulty O2 sensor throw a misfire code?
