Need to put a dead RAM into neutral
UnsatFC
Active duty NAVY
New Jersey
I have a 2012 RAM in front of my shop that will need to be towed. Battery is dead and I don’t have they keys, at this point it’s abandoned. I believe it’s a dial shifter but not at the shop to verify. How would I be able to get the truck into neutral so it can be loaded into a flat bet?
Whiteannerdy
Not sure. But if the panel pops off and the cord is there then yup.
JoeCo
NY
If it's a 12 it's definitely not the dial shifter, I believe the neutral release is in the same area though.
Pull Ya
Cedar Creek, Tx
great information--Thank You!!!!!
Jay
Tach_tech
5.7L HEMI
If it’s a 6 speed column shift, there is a hole in the bottom of the column shroud that you can stick a screwdriver in and release the gear shift, allowing you to put it in neutral.
If it has the console shifter, there is a little black cover that you remove beside the shifter gate. Same thing, put a screwdriver in the hole to press the release.
McBroom
Denison Tx
Hemi 6.4L
Take the driveshaft out. 4x4? If so might have to take the front shaft out too.
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
Thanks for the info...I’ll check the dead RAM tomorrow morning.
