Nerf bars
thekevin
Will stock nerf bars from a 2015 crew cab fit my 2017. I see a lot of aftermarkets show 09-17 but wanted to make sure the oems were the same. The guy with them for sale says 09-15 on the ad.
MarshRam
2014 SLT 4x4, 2012 ST
Ask him the spread on the mounting brackets and then measure yours. I believe my 2014 has a 72" spread from end to end with option of center bracket in between at 36". If it is the same, it should fit, not sure if you would have to customize the bolt portion which I had to do for my aftermarkets. Get picks of where the bolts go to compare. Crew vs. crew, quad vs. quad will be a factor as well, I assume you have a crew cab....
