New Member with an EMERGENCY!
WNGME
Spring, Texas 77389
Cummins 5.9L
New Member with an EMERGENCY! I drive 2007 Dodge Ram 2500 Mega Cab 4x4 with the 5.9L. Recently my truck was broken into on the right passenger side. The top side body gasket/seal material was ripped up. Having a hard time finding a replacement. I have contacted many dodge locations, all the online locations, aftermarket locations that I am aware of. Like Jegs, Summit, Carid, Geno's, Precision, called Canada the Mopar Manufacturer. The item has been discontinued. I am asking if you could contact After Market vendors in your state. Using the part number below. When it rains it pours down here in the Gulf Coast. I have it sorta tapped up, but afraid with will still leak. I would appreciate any help you can. The junk yards around here already have these seals damaged. Not something commonly needed.
I am hoping some vendor has one left on the shelf. Please help.
Body Side Seal, Right - Mopar (55277034AB)​
2006-2009 Dodge - 55277034ab
I don't understand Dodge/Mopar/Stallantis not providing a source. At least sell the mold to someone.
I was planning to restore my whole truck in a couple of years. The whole nine yards, Planned to keep it till I passed.
Thanks, WNG ME
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Sorry but these have been discontinued and there are no dealers showing any inventory left.
- Benny
Atcer2018
Virginia
Thanks, WNG ME
If this part is the body to door frame seal that has a foam bulb on one side and a J-channel reinforced with metal on the other it comes in a generic form. While the generic version may not have the pre-formed bends it can still be used on most vehicles. Possibly stop in a local body shop and ask what they use when an OEM seal is not available.
Find a catalog put out by STEELE RUBBER Company
If you go to the MAJOR swap meets, like the old BIG 3 auto swap meet, a Steele Rubber trailer will be there
Is it a seal around a door window or a seal around the door ?
W
WNGME
Spring, Texas 77389
Cummins 5.9L
Seal attaches to pinch rail on body along the top of both doors. The top of both doors shut against the seal. There is a bubble above and below the J channel
RamDiver
Marlborough, Ontario Canada
2021 DS
Rockauto.com has listings for other parts in that vintage. You may have to investigate other alternatives that are a close fit.
I don't know if this is exactly what you're looking for but they list a Mopar 55277030AC.
Their site has detailed listings with lots of pictures.
W
WNGME
Spring, Texas 77389
Cummins 5.9L
The junk yards around here already have these seals damaged. Not something commonly needed. First place I went.
Already checked Rock Auto.
I have been online 2 days now looking into aftermarkets Steele Rubber was new to me and I checked but no go.
Thanks for all your help
Dean2
Near Edmonton
Hope this helps
RBAT
Another aftermarket listing for that part but it shows that it fits either side so it will probably be different.
Bill Copple
Tulsa, OK
I put your posted part numbers in Amazon search and had MANY hits including original manufacturer parts
Phillip Franklin
San Antonio
6.7 Cummins HO
Try Steele product…. Google for website. If you aren’t having luck finding the molar part they make all kinds of rubber. Product of great quality. You just need to know what the gasket looks like.
Stephenville newfoundland Canada
2014 outdoorsman
Thanks, WNG ME
have you tried rockauto ?
Marshall
Sk, Canada
2014 sport
I just talked to Govn't salvage ( Auto insurance , in Sask. Canada)
Fellow has none on the self, but thought between 3, 4 depots there should be good ones still on the wrecks ,They would have to go check, and I am too far away to check, 4 hrs.
Auto Salvage and Parts sales www.sgi.sk.ca
Marshall
Sk, Canada
2014 sport
BTW , have you checked that the door is not bent out?
Tominator223
I’ve been looking for same one on a 04 quad cab. Hard to find these days. The 02-06 had a recall on em . So they changed mine in 05 or 6. But I get a lil water on pass. Door now in rain. Seems like I’m always looking for weather strip & window sweeps now days. 04 5.7 415k and going
Glowz
