Xolornet
2016 ram 2500 Laramie with the alpine system and factory subwoofer. I removed the factory sub and installed a custom box, single Alpine S-W12-D4 and an Alpine a60M mono amp fed by a line output converter tapped into the front door speakers.
Recently I’ve lost all sound from speakers. Started by audio cutting out at times and returning but seems to have gone completely silent now. Started happening when I installed a new subwoofer box (more air volume). Oddly enough, when the truck is on and I tap the door speakers, it emits a bass sound from my subwoofer and a faint bass sound can be heard from all door speakers.
I’ve disconnected batteries for 30minutes, disconnected factory amp for 30minutes, disconnected all aftermarket audio, checked and replaced fuses and a few other diagnostic tests I found on other forums but still nothing. Note this setup worked fine with no issues when using a smaller subwoofer box but still no audio after disconnecting. I suspect the factory amp went into protection mode or possibly failed due to the increased air volume from my aftermarket subwoofer box which would demand more power.
If anyone has any insight it would be greatly appreciated!
