Non touch screen to touch screen help please!
Sswyers
So I have a 2011 ram outdoors men with the regular radio non touch, but my buddy is selling a touch deck out of a 2012 I'm wondering if this is just a straight swap or is it not worth the hassle?
Thanks in advance!!
1500ram12
5.9L Cummins
Is it a oem or aftermarket unit? Oem will be a direct plug and play swap. Aftermarket will take a little modification to get it to fit.
Sent from my VS985 4G using Tapatalk
S
Sswyers
It's oem. So I don't need no adapters or wiring anything?! Thanks a million!!
Etroze86
Grand Forks ND
No adapters but there is a second module if its and RBZ to use the uconnect functions. I've done the swap its easy.
S
Sswyers
Ok awesome thanks a million!
baum
savage, mn
2015 Laramie
dont you need the vin "turned off" from the first vehicle?
jawzs2
Air Force
South Jersey
Possibly, it the radio has "Antitheft" stamped in the lower left corner by the volume knob, you will need the unlock code. If you don't have the code, it can be obtained from the dealer, but you'll need the vin of the vehicle it came out of.
Etroze86
Grand Forks ND
Yep what was said above I forgot that I had the unlock code provided to me when the swap was done.
S
Sswyers
Ok perfect I'll make sure I get that !!
012RAMbo
West Monroe, La
Check on the back of the headunit. I'm trying to sell one and Chrysler said the unlock code is written on the back. Let me know if it works please.
