Oem brighter fog bulb replacement?
Txhemirt
Lubbock, Tx
Are their any direct drop ins or are they all gonna be high dollar like the ones offered on retroshop? Of course I want to do it right but if theirs a bulb I can just swap out that would be awesome.
Blackdodge2010
Alberta Canada
I run Putco Ion Spark bulbs in my factory fogs. They are much brighter than the originals. I bought them from a local 4x4 shop here in Alberta but they are readily available online.
Txhemirt
Txhemirt
Lubbock, Tx
Thanks man. Any chance u have a part number ?
Blackdodge2010
Alberta Canada
I don't think I have the part number. It's been almost 5 years since I put them in my truck and I probably long since threw out all the packaging. I will take a look for you and advise tho. Also my truck is a 2010. Im not sure if the bulb would be the same for your 2016.
Blackdodge2010
Alberta Canada
Sorry about the slow reply, got busy here with work. I found my old invoice for the Putco bulbs. I'm not sure which one you will need for your truck but here are the part numbers.
mtnrider
Georgia
The fog light bulb is a 9145 so you can search for a replacement LED bulb on Amazon or something. Word of caution, the 9145 is very similar to the more popular 9005 bulb and the 9005 is often listed as interchangeable. However, I tried a couple 9005's and they would not fit properly in my fog housing.
MADDOG
Living in a Firepit
I've tried Putco halogens before and they were pretty good bulbs.
Now I use Putco's LED bulbs in the foglights and they work awesome.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I just pulled my fog bulb and it's a 9006 from the factory, what is a good upgrade in a standard halogen bulb for the 9006?
I already did my low and and high beams with Philips H9 and 9011 bulbs and I'm good with the difference they made.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Halogen upgrade;
Fog Lamp - 9006 to 9012 - Trim one external ear of bulb mounting tabs.
Low Beam - H11 to H9 - Trim of an internal tab on light bulb electrical socket
High Beam - 9005 to 9011 - Trim one external ear of bulb mounting tabs.
mtnrider
Georgia
Be aware there is a change in bulbs on the newer years (18-19). The 9006's that are posted above are not for the OP's 2016 truck. Those would be a 9145 like I posted earlier. Just clarifying so no one buys the wrong bulbs
2016Bighorny
Wisconsin
Halogen upgrade;
I conquer! I did this ( to all 3, as well ) and it is great!!! You can get replacements easily and they are very bright. MUCH better than stock!!
chrisbh17
I still have the Hikari (non-Ultra) waiting to go into my truck. I wish the weather would cooperate.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I used the non ultra in my 2014 fogs, my wife's Altima headlights/fogs, and my father-in-law's 2012 RAM fogs. Great bulbs for the price so far!
pacofortacos
My 2016 had 9006 from the factory in the fogs.
So I would suggest, pull one to verify.
