oem mopar gears 3.92 or 4.10
steermaster
CO
5.7L
I went from 3.55 to 4.10 and it was NIGHT AND DAY! I absolutely love em! I have a buddy that has 3.92 4x4 woudl you suggest him going to 4.10 or not much difference?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If he already has 3.92's, I would save the money and stick with them. The jump from a 3.92 to a 4.10 isn't enough to justify the cost, especially with him being 4wd and having to do both axles.
vcode70
Hey Matt, on a truck like your race truck, how many tenths do you think the 3.92s would cost you compared to the 4.10s you run? Thanks!
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
About .1-.2 in the 1/4 mile. I wish I had 4.56's in the blue truck. I think I could knock an extra tenth or so off by swapping to a 4.56.
vcode70
Good to know, thanks Matt! Do you think anyone will ever come out with 4.56s that fit the ZF/Mopar LSD that won't require machine work? Or is that impossible because of the size of the gears?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Its not impossible, but the aftermarket just hasn't shown any real interest in producing these. Ideally, I would like to see Eaton make a TruTrac differential that is just double drilled to accept both the ZF and non ZF ring gear.
california
california
How about 3.55 s to motive 4.56????
Or 3.55 to oem 4.10????
Have to love the pricing on those motive gears
but i mean are they plug in play just like oem or what is the difference pricing speaks alot for them personal opinions will really help
this will be my next mod??/
Tyler76
Mother Russia
Guys, failed to find large sticker on axle tube, so how can I find out my gear by VIN?
Tyler76
Mother Russia
finally I wrote here: [email protected] and in 2 minutes they answered that I have :
DJGS 215MM Front Axle
DMD 3.55 Rear Axle Ratio
DRNS 235MM REAR AXLE
DSA Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
EZH 5.7L V8 HEMI MDS VVT Engine
so, guys, to be faster at 0-60 should I go 4.1 gear or what? Is it safe to do that stuff (warranty etc) and what would be the budget? What are the disadvantages of going this way? Fuel consumption?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The only bolt on gears for the 2011-up Ram trucks are the OEM/Mopar gears. The cheaper aftermarket gears will only fit up to 2010 unless you machine and re-drill your carrier to accept the bolt pattern of the aftermarket ring gear. In the end, the price comes out about the same after machining cost.
Copperhead7310
Chattanooga TN
2014 Big Horn CCSB
I just went from 3.55 to 3.92 and it's definitely an improvement. I'd say 4.10 but do you do a lot of highway driving? 3.92 might be a nice balance (?) just a thought.
Tyler76
Mother Russia
Copperhead7310, I do 30 miles a day of highway driving, what's the point?
Copperhead7310
Chattanooga TN
2014 Big Horn CCSB
Just a little fuel savings, if you're concerned with that. 3.92s are pretty snappy compared to the 3.55. 3.92 to 4.10 is not that much at all though.
If you're going to be a bear, be a Grizzly. Im under the impression youre not really concerned with gas mileage.
Tyler76
Mother Russia
Copperhead7310, so, did I get you right...
1. It will work fine with 8 speed trans - I have only to select btw 3.92 and 4.10?
2. Fuel cons would be almost the same (yes, it is not so important)
3. Why didn't you choose 4.10 ?
4. You have 8 speed?
5. any disadvantages - for ex more stress pressure to transmission?
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
+1 not worth it in the 4x4.
badvik
From Russia with love
2013 Laramie
ZF 8HP70
Matt, could you quote the parts need to swap to 4.10 with the parts above?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The only way to swap to a 4.10 front gear on a 2012+ is to buy a new front axle from an 09-11, new front driveshaft from an 09-11, then aftermarket 8" front gears and install kit. It is a very expensive swap.
