Offset Rims and Spacers
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Good evening,
I was sitting here in my shed looking at my 2” Supreme Suspension wheel spacers I run with my 35/12.50/24 tires. I run 37/13.50/20 with a -51 offset rim currently. I switch them out when I get bored with the tires/rim.
My question (haven’t done this yet) what issues/if any, would I have running my 2” spacers with my -51 offset rim/tires? Truck has 9”s of lift.
Thanks for any input. Negative/positive input also welcomed.
crazykid1994
A lot of extra stress on ball joints and wheel bearings. -51 is already quite a bit. What is the actual rim dimension? 20x? -51. With the 2” spacer A 20x10 -51 wheel would extend your wheel 5.25” out past stock. 20x12 would be 6.25” out past stock. Remember the farther out you go the more the tire is trying to twist the ball joints and wheel bearings instead of pushing them up and down.
Meatman8769
Comox, bc
Good evening,
This offset is epic! I'm running 20x 12 on 33s. -44offset. Just Levelled. Looks mean as hell. Debating throwing on 2" spacers to pop em out more. Also worried about the extra stress. But also they are bolted the f on for reason so what's the worst that could happen lol
That would put a load of weight on your spindles
Taking corners at speed stresses everything even more
If you don't mind changing bearings out every month or two if you drive on country roads with a lot of corners & a lot of braking. You would have a good looking ride if you have money for bearings & time to fix it.
My issue was the bearings would go bad when i was on the way to work.
Lyle Longboat
Lyle Longboat
Bought a 2005 Dodge ram 1500 5.7 4x4 SLT and the spacers going on that with my 35/12.50/24 rim/tire setup. The red beast stays as is until I find 35/13.50/20 to go on the 20x12 -51 rims.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I have 20x12s -44 and that's as much as I will do especially on 1500s .... like everyone else has said, way too much stress
atreides
USA
With great stance comes great responsibility of replacing wheel bearings annually (probably an exaggeration).
2018 2wd
RedSRT4Me
Scottsdale, Az
2015 CC Sport
