oil change
gilleydog
florence az
2017 ram larami
4000 miles and 2 oil change dealer did 1st one, witch oil redline or pup using royal purple filter
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Its really up to you as both are great oils and O dont tjink you can go wrong either way.
Pup 5w30 is probably cheaper than RL 5w30.
The Filter you pick is maybe one one the best, One I just found that migjt be better is the Amsoil filter.
Burla
2010 Hemi Reg Cab 4x4
Those are top two choices IMO. PUP seams to have best wear numbers and redline is the best at combating unwanted ticks. Both of those features are ahead of the field, which do you value more?
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Neither; Amsoil or Quaker State Ultimate Durability (Gold label and/or Gold cap) will serve you far better. Check the link in my signature and see the oil testing data for yourself. 216 oils tested and compared.
If your dead set between Redline and PUP, go with PUP. Far better than redline and has good thermal stability.
G
gilleydog
florence az
2017 ram larami
my 1st time doing a oil change in my drive way 2017 ram 4x4 5.7 any problems with the oil filter getting off and on ? looks like a real pain
Rampant
NJ
392 Hemi
A 76mm filter wrench with extension would be your best bet, similar to the one pictured. Some use a small paint mixing/measuring bucket or similar to make the job leaner.
@RLK may be able to give you the info on the small "bucket" he uses.
grizzstang
Calgary, Alberta Canada
Put the front of the truck on ramps or jack it up and use jack stands. I changed mine the first time on the ground and it sucked. The last time I used my ramps and it was so much easier. Attack the filter from the front over the engine cross member. I use a good set of oil filter pliers for removal of the old filter. With the truck in the air I just let the filter oil drain down the back of the electric power steering box and wiped it all clean when I finished. I tried to get a small funnel or tub under the filter but had no luck.
Burla
I use ramps everytime, be on a flat surface
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
NM: FF has already been removed.
Good advice above.
G
gilleydog
florence az
2017 ram larami
finally changed the factory oil and filter with reline 5w30 and a rp filter took it for a 60 mile round trip (hiway) pulled in the garage and it sounds a whole lot smoother
