RodRamCar
- Jul 7, 2022
- 338
- 449
- Location
- IdaHO
- 2022 Longhorn
- 5.7 4x4 w/ 3.92s
It's honestly hard to tell how it's performing. I mean the oil i'm using is about to get changed back to RL 5w30 because i tried Mobil 1 5w20 and Lubeguard. What I don't like is that there's occasionally some tapping sounds at first start up for maybe 2-3 seconds. Doesn't sound like E Man leak or anything and it didn't do that on 5w30 RL so we will see how 5w30 RL and XG2 together do. I did like the RP 20-820 and RL together but that 20-820 filter seal sprung a leak and it was plenty tight.Imo, they both are about the same. One having a larger diameter case(FRAM ULTRA XG2) versus the (FRAM Ultra 10575)and are almost identical in heighth with the exception of the XG2 has a wire back media and the XG10575 doesn't.
If the XG2 is performing well for you then you have found your filter.
Some folks are going to those filters as an temporary replacement oil filter until the stock on the Royal Purple 20-820 becomes available.
