c713
- Joined
- Jan 24, 2023
- Posts
- 13
- Reaction score
- 21
- Location
- Regina Saskatchewan
- Ram Year
- 2016
- Engine
- Hemi 5.7
Good day to all. I'm new here and glad I found this site.
So a bit about me - I have been in the auto business (family used car lot) since 1983.
Not much has got by me that we haven't been able to figure out but about a year ago I bought a 2016 Ram 1500 Tradesman Short Box 4x4 regular cab with a noisy 5.7.
Most of the noise was the exhaust manifold on the passenger side but we put it in the shop. Removed intake, exhaust manifolds and heads, camshaft and lifters. A couple of the lifters were bad so we did just put in a stock cam and lifters. Had the heads professionally done, all the valves, seats, guides, planed the heads, all new gaskets, new bolts for the exhaust manifolds. Everything went great. Drove it a few months and then noticed a pretty bad oil leak (I will post photos) coming from the passenger side leaking down the back of the engine and pooling on the floor.
Not much that the oil went down a lot but a mess for sure. Now there are no engine lights are on, the truck does not lack performance, starts and runs fine. No issues with driveability but you will see the leak, and I can't figure it out. Took it to a friend that has a shop and he indicated to me that it's coming from the seam of the intake (I believe these are 3 piece intakes pressed together). So I took his advise, found a used intake from an 18, new set of felpro intake gaskets. Installed the intake from the 18 and drove it maybe 5kms maybe not even. Got home and I could smell the oil. Opened the hood, took a look and yep. Seems to be in the same place but a heck of a lot worse. So installed an oil catch can, vented the breather with a K&N filter and still the same. Now just to clarify, there's no issues with start up, performance, no engine lights but this external oil leak. So I have a 3rd used intake to put on but I wanted to share some photos to see if maybe I am missing something. I never thread locked the intake bolts so I will do that next. I took RTV silicone and after thoroughly cleaning the intake I put the silicone on all the seams on the intake. I have another new set of felpro gaskets ready to install but I'll share the photos and hope someone might see something that I am missing. Any help would be greatly appreciated. Thanks in advance.
Just a note: You will see in the photos that the intake gaskets seem to keep the oil from entering the valves. The oil seems to be pooling in the little 'depressions' in the intake by the intake bolts.
Sorry for all the photos. Thanks again
Rob
Rob
