Oil temps
scHemi
2009 RAM SLT Crew
Towed a trailer yesterday and my oil temps got to 230 but no higher. Mobil 1. Do I need a oil cooler?
TylerB
FL
Nah that's normal.
BlownGP
Houston/Baton Rouge
I was going to post this.
I just took my first road trip in the hemi and it was 85-89* outside and my oil temps would stay at 215* and once I saw it at 217*. Is this normal? I wasn't towing anything.
I thought they would stay close to the coolant temp. Kinda worried me.
S
scHemi
2009 RAM SLT Crew
It just seemed high. I might do a cooler eventually
MikeG
Livonia La.
In a perfect world you want your oil temp to stay close to coolant temp. This will also help keep Copland temp down.
HLram
2012 and 2007
Hemi 5.7 in both
Mine always stay right there with my coolant temps when I'm not towing. Strange that y'alls are higher.
audio1der
Airdrie, Alberta
Travelling 130km/hr TO pick up our trailer our oil temp was 206. Travelling 100km/hr uphill with a bit of wind towing the trailer home it was 221.
Have you pulled your VIN window build sheet to see if you have the factory tow package with oil cooler? (we do)
chuck
Maryland
2013 True Blue Big Horn
I never tow and mine is usually sitting around 220 Fahrenheit after 20-30 minutes of highway driving.
Sent from my iPhone using Tapatalk 2
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Unless you have an aftermarket oil cooler, or maybe an auxiliary stock one, the oil temp will be roughly the same as the radiator temp, as that is what cools the engine, and the oil won't be any cooler than the engine it flows thru.
chuck
Maryland
This is the first hot day we've had here so far this year...supposed to get into the mid 90's by late afternoon...and I'm gonna be doing about 40 miles of (mostly) highway driving. So I'll be keeping a close eye on my oil temp. If I notice anything strange I'll post it up here.
erie_one
2013 1500 laramie 4x4 quad cab
hemi
Mine runs 10 plus deg. higher than the coolant temp empty.
emjohn4
I found this on the Z forum
Pretty cool, wonder how much it effects the air hitting the radiator.
Derale Tube-Fin Engine Oil Cooler Kit w/ Spin-On Adapter (Multiple Threads) - Class III Derale Engine Oil Coolers D15551
I LOL'd, hard, when I saw them using white teflon tape on the fittings.
That's a no-go right there. It also tells me they have no credibility.
The oil to air cooler would likely be more efficient than the oil to water cooler - but I really don't like the simple hose clamps to keep your oil, well, internal to the engine.
BlownGP
Houston/Baton Rouge
I've used Teflon tape on my oil pressure gauge on my Grand Prix. Been mine for many years now.
emjohn4
NPT thread? You didn't need any tape.
If you've been fine with white tape - you also would have been fine with *no* tape.
Petroleum products will eat the white tape.
MikeG
Livonia La.
Tube and fin coolers are less efficient then plate and fin
rraulston
Sahuarita, Az
2018 Ram Rebel
Take a look at the pic in this thread and then talk to me about oil temps....500 miles of this and it ran like a top. Diesel oil will go into the 300 plus range. Not towing and mine will be plus or minus 20 degrees from the water temp.....The tranny coolers on the 6 speeds are amazing.....
http://www.ramforum.com/f119/serious_towing_conditions_yesterday-31826/
