stc315
My 2014 Ram 1500 5.7 had wicked lifter knock and has 135k miles so I swapped out the MDS cam and lifters and all of the valvetrain (springs, locks, retainers, pushrods, etc.). I also put MDS plugs in place of solenoids. I had previously added a Diablo Sport Diablo 87 tune and shut off MDS. Now upon restart, engine won't stay running unless I keep the accelerator pedal down (about 1/4 throttle) and dies when I let off. It runs very rough and I get P0300 multiple misfire code. I also added new spark plugs. I have no idea where to start. I double checked all connections and have no fluid leaks I can see. Background on my skill level, I'm a mid level mechanic (basic diagnostic skills on muscle car era engines). I have good mechanical skills though (remove and replace). I made sure I kept the timing chain tight and the timing marks all lined up when I added the new cam. I kind of wonder if I have a vacuum leak, but can't find anything not connected. I did notice a hose that runs along the drivers side of the intake manifold that's not plugged into anything but can't find anything to plug it in to.
