P0441 code
etuke
Newfoundland
Just got this code on my 2014 ram 5.7,checked it with AlfaOBD and the description says check not completed temporary.I used Alfa to do a manual purge check and I'm not seeing any current on the purge valve for any test(open,closed and finish) would this mean an open purge solenoid?
E
etuke
Newfoundland
When I go to the pumps I always fill it up.Last time to the pumps was back in august and this only happened yesterday.
E
etuke
Newfoundland
If the overfilling is the cause and the canistor is the culprit is there any thing to do other than change it out?I checked the purge valve today and it is working.
Burla
2010 Hemi Reg Cab 4x4
If it isn't that bad as in your gas pump doesn't click off every second when attempting to fill, maybe time will help. You wont pass any emissions test though duh. I wouldnt want to add anymore by topping off if that needs to be said. And you have no fresh gas smell?
E
etuke
Newfoundland
No gas smell and the tank fills properly,no shutting off.No emmissions tests here to worry about.
Burla
This is not an emergency situation, it is possible the vap will escape, keep clearing code and do a hard reset.
