Parts list for a 5" or 7" lift
CStank89
Hicktown Ohio aka randolph Ohio
99 1500 4x4
Quick question. Does anyone have a complete parts list for a 5" or 7" lift.. I know there's much more going into a 7". I had someone making one but he got a little busy and wasn't able to finish it. I'm not new to lifting or fabricating as I have lifted and owned SEVERAL jeeps in the past and present.. But I am new to lifting these trucks.
Thanks,
Christopher
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Johnn123
Ontario
And if I go 5 are La's highly suggested?
For a 5" lift you will need lift springs, lift leafs (dont use blocks), a track bar drop bracket, a pitman arm drop and the appropriate control arms. Long arms are definitely suggested but there really isnt anyone who makes them for these trucks. The only kit ive seen is a Fabtech kit with long uppers and short lowers and it cost over $2k. Im planning a 5" lift in the spring time and thats what Ill be using for my lift. Not sure what you need for a 7" lift but I assume the same pieces but for 7".
C
CStank89
99 1500 4x4
Well one of the issues I've ran into is finding full leafs. Only thing I've found is AAL's. I'm waiting on Marc to chime in
Merc225hp
NA
truck
gas
Skyjacker DTBA27 trackbar $300
Skyjacker D50 or D70 Coil springs $200
Short control arms approx. $300 for the set
as for full leaf spring packs you can look at skyjacker, or a couple of other makers leafs
or this site Custom Suspension
Skyjacker D600 drop pitman arm
Shocks are up to you.
ChillyPhil
Pennsylvania
5.2 Magnum
I have a RC 5" lift with stacked blocks. If you go that route, just make sure they're torqued right and stay that way. Just don't be going all out and burnin them off or jumping jumps or anything.
Johnn123
Ontario
Stacked blocks I dont recommend unless its NEVER going to go offroad and it should be babied around while driving. Things aren't safe IMO. AAL's would be a better option. Skyjacker has lift leaves as well I believe. Merc's part list should be all ya need for the lift as well.
