It's not that simple, it changes the response speed. If you ram the pedal to the floor it will still take some finite time for the throttle to go from closed to fully open. The PC makes that response faster. You can't duplicate that by ramming your foot faster since the stock electronics will only respond so fast and that all.
I understand what you are saying, but I don't see how this can happen.
We cam assume that there is more than a variable resistor in the throttle peddle assembly since there are 5 wires in the connector and you only need 3 wires for a simple potentiometer. So this can introduce some delay.
But since the PC is installed in series with the peddle, the same delay should be present "before" the PC sees that the throttle peddle has moved. Your saying the PC can anticipate what the throttle peddle is going to do.
Any company that sells something will tell you it is a wonderful thing, but these claims seem unfounded.
I just think the increased sensitivity is fooling people into thinking this thing is more than it really is.
The company also claims a 20% increase in fuel economy...which seems a bit much
Sorry........I am almost tempted to try their 30-day satisfaction guarantee but since I drive like a grandpa (I am one) I am not looking for a performance change like this.
Regards,
Dan
