jtoscano19
I was just told my exhaust manifold gasket is leaking alittle and since they're gonna take everything off to replace the gasket..might as well put in some headers! Which ones would give me the most low end power?
i loved my bbk shorties, i felt a noticeable low end gain, plus there a direct bolt in
Budakane said:Pacesetter Long Tubes FTMFW!!!!!!!
Don't go catless and you will not need a tune.
Look at JBA headers as well before you make a final decision.
Use good quality gaskets and some Stage 8 fasteners vs. re-using your stock manifold bolts.
Shorties would be the easiest and direct replacement basicaly. Make sure you order a new set of Mopar gaskets also when you do it, the ones all the companys use are crap.
