- Joined
- Jan 17, 2016
- Posts
- 23,732
- Reaction score
- 54,509
- Ram Year
- 14 Sport
- Engine
- 5.7
With those engine temps it sounds like the truck has a 180F thermostat,instead of the stock 203F thermostat.Switch your evic over to the SAE settings,and then you'll get the engine temps in farenheight instead of celsius,you should also get your oil pressures in PSI to. You're basically on a US site,so PSI and Farenheight are the more common readings here.Ch!t i'm a Canuck and i don't use Celsius or KPA ,as 50 psi i understand at a glance,along with 185 farenheight,and you're making me go look up your temperature readings,as 92C and 85C don't really mean squat to me,lolWhats a 180 thermostat? It’s stock ram 1500. Only mods are magnaflow cat back and S&B induction.
You can go look up 180F and 203F this time around,lol
