Poor gas mileage
timstites45
Colorado
Hello everyone I have a 2015 ram 2500. I’m running 35 inch tires. I wanna know if anybody else is getting 8 to 9 miles to the gallon. I spoke with another guy that said he’s getting 14 to 16 and he’s got a 2020 ram 2500 with the 6.4 hemi and I have the hemi also 6.4
olyelr
Kewadin MI
Pour? Haaaaa
You wont do as good of mileage as the ‘19 and newer ones with the 8 speed trans. Dont even bother comparing to them.
I have a ‘16 power wagon, and have gotten around 12 mpg for the last 130k miles since it was new. I think i squeaked 13mpg out of it once in its life, but never more. It does have 35’s on it, but the mileage didnt really get any worse.
You should be getting somewhere around 12 at least, unless you drive like a complete @$sh0le lol
Govtman
Oklahoma
Pour? Haaaaa
Can also take revs per mile for your tire vs. the factory size and see how much more % wise the larger tire covers. Say If it's 8% more you can add that % to your mileage.
Does the truck have the optional 4.10 gearing? Was the speedometer/odometer corrected for the new tire size?
As other have mentioned, don't try to compare to the newer version with the ZF 8spd. For comparison 1st gear of your transmission is equivalent to 2nd gear of the newer ZF 8spd. It also has two overdrive gears and 8th is taller than 6th in your transmission.
olyelr
Kewadin MI
Not if you do what should be done, and reprogram the computer for the tire size so everything is back in sync. Including the shift points.
olyelr
Kewadin MI
I see a winch in the front bumper, so guessing its a power wagon (4.10’s).
Govtman
Oklahoma
For that size tire I would. I went from 33(275/60/20) to 34 (275/65/20) and it feels like the 1500 hemi should have had 34s from the start. Speedometer off by 1mph at 65.
olyelr
Kewadin MI
Yea when i went from the factory power wagon 285/70/17 (33’s) to the 35’s it was absolutely horrendous before i reprogrammed for the change. The shift points in the trans were so screwed up.
I still wanna regear to 4.88’s or 5.13’s so bad, just havnt done it yet.
If your speedo is off a bit, just change the tire size on the programmer a bit. Its been so long i cant remember, but i think i set mine to 34”to get the speedo dead accurate.
Govtman
Oklahoma
I noticed with the factory size 33" it was off on 1 mile check, when I went to 305/55/20 33.5" on back the odometer was correct.
So odometer runs out sooner with factory size tires than it should. How convenient for the car mfg having vehicle run out of warranty before it should.
Alamedasam
California
I have the same, but 2019. The algorithm changes with the tire size. I spoke to a long time Ram executive who checked my data & found I’m actually (most likely) getting the 15-16 mpg.
Tire size absolutely changes all the readings for fuel use, mileage, miles driven & speed.
So far nobody has the program to do a tire size reset on our trucks with the hemi.
So I guess we have to live with reality v’ observed data!
06 Dodge
Forest Grove, Oregon / Osage Iowa
6.7L CTD
Have you looked to see if it can be done with Alfa OBD when using a security bypass cable?
TXrebel2019
5.7L hemi
The newer vehicles get better gas mileage from what ive seen. I had a 2020 1500 tradesman classic 5.7 hemi and it was really good on gas. 20 - 22 mpg and that doing around 78mph.
Sunmerk
