- Jul 17, 2012
- 9,421
- 4,703
- Location
- Conroe, TX
- 2014 Ram 1500
- Whipple Supercharged 422" Hemi
Moe's Performance Hemi CNC Ported Throttle Body is back!!! Our new 5-axis CNC Ported HEMI Throttle Body was created to increase airflow through the stock intake manifolds of the new hemi engines. The stock 80mm throttle body has proven to be a restriction on these engines but with our new venturi-like design, airflow through the stock throttle body has been increased without sacrificing air speed like some of the straight bore 85mm throttle bodies. This allows even more power while still being a direct bolt-on part.
As seen in the picture below, the bore at either end is kept in the 83mm range as to not require intake porting. At the point of the shaft the throttle bore is 85mm, and the 80mm bore is only maintained at the idle and low speed throttle positions.This will eliminate the need for custom tuning while adding increased hp and throttle response at higher throttle positions.
04-UP Dodge Ram 5.7L Hemi - 85MM
CNC Machined for the best fit and finish
8-12 RWHP Gain!!
Better throttle response
Quicker acceleration
What more can you ask for than a straight bolt on with no tuning required.
These normally sell for $339, but we were able to port a batch of low mile cores and will be blowing these out at $100 off normal price...$239 with FREE SHIPPING. We only have 4 05-up TB's and 2 03-04 TB's left. Once these are gone, we will only be offering them as brand new ported TB's for $339. These are going to go fast at this price, so I am not even going to add them to the site. PM me if you would like to place an order for 1 before they are gone.
8-12 RWHP Gain!!
