Problem rotating 6.7 by hand
Miki
Hello, did some ARP head studs today. Took all the rocker arms off and kept in order, re installed and went to turn the crank to TDC.
Half way through the rotation it suddenly stops. No amount of force will push it further.
Tried the other direction and still it stops
Trucks a daily driver.
Only issue i had while doing the arp install was when the pushrods were going back in sometimes they could drop too far, and they would sink almost to the top of the rod
Any help would be really appreciated thank you
Daw14
Start to recheck all of your work,it wasn’t like that when you began ,double check you erred somewhere.
M
Miki
Found my issue. Most likely didnt seat a pushrod properly and now my rods bent ☹
Orca
