Protecting back up sensors?
Docwagon1776
Midwest
I'm not sure why Ram decided to put the back up sensors where they are instead of flush mounting higher up on the bumper, but it leaves me a bit concerned that a failure in judgement on departure angle could leave me with busted sensors. Is anyone drilling the bumper and refitting them higher, and if so does that cause any issues? Alternately, is anyone just using one of those hitch installed skid plate things to give extra protection? If so, which one?
soapy
Northwest
6.4 hemi
Supreme Suspension makes a trailer hitch skid similar to the one made by retired. It works and won't set off the rear sensors. Under Body Armor also makes one but it will set off the rear sensors because it is too big.
2003F350
6.7 CTD
Interesting that they moved them lower like that. On my '17 they are much higher in the bumper...which has its own drawbacks, as that lets them sit in compacted snow/ice in the winter, which CAN (happened to me) let water seep past the seals and crack the housing, leading to failed sensors.
Seems like putting them lower puts them more in line with the spray, and as you note leaves them more susceptible to being damaged by everything else.
Travelin Ram
@2003F350 , if you can post a picture showing your sensor locations I may just break out the drill and move mine. I’ve a suspicion they won’t work properly if anything moves, and I’m certain the dealer will not be of any assistance recalibrating them (assuming it’s even possible). But I don’t really value them anyway, that’s what the rear camera is for.
White six four
Wisconsin
This is on my 16 if you zoom in you can see the black sensors on the rear bumper.
soapy
Northwest
6.4 hemi
Here is a picture of the Supreme sSuspensions hitch skid. It came with a recovery point for a D ring. The tow point is drilled for a 7/8th inch pin which can be hard to find so if you are looking at this order it with the 7/8 pinned Dring included.IMG_7519.JPG
Docwagon1776
Docwagon1776
Midwest
I ordered one. They have a 12% off code right now on their website. With no offer code, they are actually cheaper through their ebay store than their website.
Adventurebound
Las Vegas
Here is a picture of the Supreme sSuspensions hitch skid. It came with a recovery point for a D ring. The tow point is drilled for a 7/8th inch pin which can be hard to find so if you are looking at this order it with the 7/8 pinned Dring included.View attachment 509424
Is that recovery point just welded to the top? That looks super sketch, I've seen welded recovery points just rip right off.
grimmecm
Atlanta
Ive had this same concern since day 1. Anyone thought/tried to drill holes higher into the bumper and relocate them? It been on my mind, but I'm a coward and would prefer not to be first.
Docwagon1776
Docwagon1776
Midwest
What sleeve are you using to adapt the 2.5" receiver down to 2"
soapy
Northwest
6.4 hemi
My pickup came with a sleeve from the factory that is aluminum. It was in the storage bin behind the drivers seat.
Docwagon1776
Docwagon1776
Midwest
Hmm, I don't think I have one. I picked up one at Lowes to try, but I'm returning the Supreme Suspension hitch armor. It's pretty loose, measures 1.958" with my calipers and it noticeably wobbly in the sleeve. To eliminate the issue being the sleeve I tried it in my son's 2" receiver and it was wobbly in there as well. I'm afraid it's going to be a source of rattles plus I didn't care for the way the recovery point is welded on once I got it in my hands. I'll have to try something else.
soapy
Northwest
6.4 hemi
I have never noticed a rattle with mine. I looked at some of the anti rattle trailer hitch devises but none fit because the hitch is mounted so close to the bumper. For a recover point you can pull it out use a style you like. I have tried others but they are bigger and trigger the back up sensors when backing up.
KAKA
