Put on Tow mirrors today...might take them back off
Mr_Nacho
Saluda, S.C.
How much vibrating do the OEM tow mirrors do while in either position going down the road? I got some off of 1A Auto and so far am slightly dissapointed, but I don't really know how much the OEM ones move around.
RYAN66
Denver, CO
5.9 cummins
my passenger one vibrates a good amount, mostly because of the engine rumble.
WhiteExpress
Midland, TX
The factory Gen II tow mirrors have absolutely zero vibration in them.
The aftermarket ones vibrate like mad.
My guess is that's true through-out the generations.
Ramunit
Not speaking of tow mirrors specifically but every aftermarket mirror I've ever bought viberate like crazy, nothing like an OEM IMO
Mr_Nacho
Mr_Nacho
Saluda, S.C.
Ram'em said the ones he got from 1A that had the chrome and light on them didin't vibrate badly, but I think mine are almost to the point of being distracting. Granted I haven't driven but about 5 miles with them. Mopar ones I found on ebay were 150 bucks more than these, but you get what you pay for I guess.
Cthulhu
Calgary, AB
Cummins 5.9
My OEM mirrors are pretty stable.. my driver side seems to have a bit of quiver in high winds, nothing overly irritating though. Its less noticeable when in the 'tow' position.
reddot
Wolf Point, MT
5.9 cummins
my mopar ones dont move at all and if they do ive never noticed it. And this is one thing I would notice. Hate when they vibrate!
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Just out of curiosity. Did you install the reinforcement plate?
Sent from my DROID RAZR using Tapatalk 2
Mr_Nacho
Mr_Nacho
Saluda, S.C.
Aren't the reinforcement plates only used on second gens? When I searched in ebay all that came up was for '94 to '02 models.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Hmmmm interesting. Maybe I was miss reading the ads and instructions. I thought all tow mirrors needed brackets. I'll have to look into that more.
txbass06
NE Texas
5.9 Magnum
I've only seen them needed for the 2nd gens too if you're addin them to a truck without them
reddot
Wolf Point, MT
5.9 cummins
yep that bracket is just for those rams generations that did not come with a oem flip out tow mirror.
Mr_Nacho
Mr_Nacho
Saluda, S.C.
Well to get the Mopar pair of mirrors I only have to fork out 145 more dollars over what I paid for these, so I guess I'll send these back. No sense in feeling regret every time I look behind me through a shakey mirror. Thanks for the input guys!
MADDOG
Living in a Firepit
Mine don't move around at all...unless the mid bass in the doors is thumping... ;)
reddot
Wolf Point, MT
5.9 cummins
from what ive read a big change between mopar and aftermarket is mopar uses glass mirrors against the aftermarket plastic ones.
inktoxicated
nj
i got the aftermarkets and they vibrate. only the big mirror. the spot mirror which is glued to the unit doesnt move at all. i just set them where i needed them and wedged a little foam around the space bettween the mirror and cover. cant even tell and it cut down the vibration. from my expereinces driving tractor trailers the ones with power mirrors all seemd to vibrate more then the manual ones. im used to those things shaking around so having the vibration at 50 mph plus doesnt really bother me but i still tried to cut it down some. i was thinking of putting fender washers on the inside where the nut goes with rubber washers sandwiched in there and rubber washers bewttween the door/mirror on the outside too. would only be like 2 bux in washers. i would imagine it would help some. looks like there is enuff thread on the bolts to get the washers on
inktoxicated
nj
i atually am a little werded out by the spot mirrors. are they supposed to be on the top corner? i would think the bottom corner would make more sense. its like it created a bad blind spot. when there in the down position. ive seen dodge tow mirrors with the spot mirror on the lower corner. mine are in the upper corner. was the glass put in upside down or something?
HemiLonestar
Navy Badge Coast Guard
MD
Mine don't really move unless I have the volume turned up on a heavy bass song...or I'm doing WELL in excess of the posted speed limit...
srtajm392
