Radio glitch
Ramses2019
Have a strange one.
While in Acc on sat radio volume will suddenly increase then a few seconds later go back down.
Dash while on normal volume
Dash when it jumps up in volume
Dealer has to go through diagnostics before they get the OK to replace the head unit.
2019 Classic 400 miles.
Anyone else have this annoying glitch?
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
Does it only do this on Sirius XM radio?
What is your "time-out" setting for radio while key is on Accessory position? In other words, how long will accessories like the radio stay on with key in Accessories position? (This is user settable in the Settings menu)
R
Ramses2019
I haven't tried on FM as I don't listen to it.
Nor have I changed any time out settings.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
I just experienced this in my truck. I was listening to my music on a memory stick. Ignition is off and I'm listening to it before I go into work. My delay is set for 10 minutes. I only have about 150 miles on the truck. I'm curious what you found.
Check the speed compensation setting for the volume(it's in the radio settings), try turning it to off. Depending on where it's set at, the radio volume will increase as the vehicle speed increases, this setting is handy for people who like to drive with the windows down.
The radio probably can't interpret the - - of the vehicle speed. The speedo reading probably does that because of the BCM shutting down.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
I have it set on 3. I'll try turning it off. Thanks
RamCares
n/a
n/a
Hi Loudram,
We certainly understand why this would be concerning. If you are not able to determine a solution based on the suggestions provided here, we kindly recommend following up with your servicing Ram dealer for further assistance. Our team is just a PM away if you do work with your dealer and further assistance is needed.
Mark
RamCares
Jtucker21990
