Evguy1
- Joined
- Feb 9, 2020
- Posts
- 375
- Reaction score
- 423
- Location
- Errington BC
- Ram Year
- 2014 RAM1500
- Engine
- Cummins ISB 170
I wanted to have a cargo cam but my 8.4 software does not support it. I only want it when backing up to my 5th wheel so I just put a switch on the stock tailgate camera. Added a DPDT sw in the little panel on the side of the console. up is stock tailgate and down is cargo cam.
Then added a camera I had kicking around into the third brake light.
Pulled power for the new camera from the backup light circuit (trailer system) at the fuse box. Soldered and heat shrunk the splice and ran it through a Weatherpack connector. After all these years I'm finally learning to label my added wires before I forget what there for!!
It's much better on the neck and marriage when backing up to the trailer.
I added a grommet to the middle of the clutch master block off plate as I'm sure there will be lots of wires to run through the firewall in the future. Just a piece of Gorilla tape over the hole till its full enough to seal up permanently.
