Rambox + Motorcycle
1011555
CA
I'm looking to get a Rebel with ram box but would also like to put my motorcycle in the box. Has anyone had any issues with doing this?
Sent from my SM-G975W using Tapatalk
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I recall an explanation & a video about the Rambox & a motorcycle
The guy opened the Ramboxes & removed the boxes, they are light weight & have several small bolts in the bed that hold them in place.
Once the boxes were out, i think that he used something to beef up the beds sheet metal on the inside.
he was able to add better tie downs to hold the bike stationary.
I know that i am not explaining to well, but i hope that you can picture it.
He did mention that while disconnecting the electrical connectors of the ramboxes, in the tail light area, he thought he had the correct connection, but it turns out that there was something else back there.
While you have the Ramboxes removed, you should maybe rust proof the inside of those cavities where the Ramboxes sit
found a video
thkbaron
Minnesota
Why does having a rambox have anything to do with putting a motorcycle in the back? I had my scout in the back of mine no problem. just get it up there safely.
GTyankee
3.0 ecodiesel
I believe that he was wondering how he could securely strap a heavy 2 wheeler into a Rambox bed
I know how i would do it
I would remove the Ramboxes & bolt metal plates inside that cavity, to beef up the sheet metal enough to mount tie down points at least in the 4 corners fairly close to the top of the Ramboxes
CA
sorry for being unclear but yes I was wondering how well the bike could be strapped down
olyelr
Kewadin MI
You strap it down just like you would with a non rambox bed. Am i missing something here? There are tiedown mounts in rambox beds too.
GTyankee
3.0 ecodiesel
There is no way that i would tie down a full size motorcycle to the 4 loops that are down at floor level, the straps would almost be vertical.
With a regular bed, you can run the straps over to the bed rails & some more down to the floor loops, if needed
I also strongly believe in a product called DG Tailgate Supports
CA
Yes it's just the tie down mounts are very much closer to the center. This is why I was asking if it was easily doable before I purchased
