Rambox + restraining motorcycle?
1011555
CA
Has anyone successfully tied down a adult size motorcycle in the bed equipped with rambox. I asked because of course they're are tie down hooks on the floor but straps would nearly be vertical with the bike.
Sent from my SM-G975W using Tapatalk
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
I haven't hauled a motorcycle in mine, but I'd probably use the tie-downs in the utility rails along with the lower hooks.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The utility rails would work, but some Ram boxes don't have them.
I think that i would take out the Ramboxes & use steel plates inside to fasten some kind of loop or fasteners to. then put the Ramboxes back in.
When the Ramboxes are out, i would seal the seams inside of the boxes to inhibit corrosion.
There is hardly any paint inside of the box that the Ramboxes fit into
mikeru
Super Moderator
Eastern WA
2020 Limited
Please disregard this post. Foot in mouth syndrome.
CA
Yes ive seen a YouTube video of someone that does exactly what your saying
Kipslonk
Mansfield, TX
I'll try to take a pic next time I strap my sportbike in. I strap couple bits of frame around the engine covers to the points in the front of the bed then the passenger pegs onto the rear points. My dream would be to have a wheel chock that are on motorcycle trailers that slides into the front of the bed so I only have to strap the passenger pegs.
RoadRamblerNJ
Mountain City, TN
392 Hemi
Criss-cross the tie downs. L. handlebar to R. side hook, etc. I always tension it by pulling rearward on my bike also. Of course, I have an 8' bed.
Sent from my SM-N910V using Tapatalk
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
My RamBox has tie downs in the lower 4 corners - on the walls. Will they not work?
GTyankee
3.0 ecodiesel
The lower tie downs are great if you have a trail bike & you are not taking it to a Show
My point is that if you have a Full sized Harley, Indian, BMW, or one of the Classic motorcycles, like a Henderson, Excelsior, Ariel Square Four
I would want tie down points around the height of the tires, if not higher
If your tie down points are not mounted high, then you have to go wider than 48".
72" is what a utility trailers rails are at & even they usually have 15" rails around the edge
