rear control arms
sickboy
seeing as almost every lowering kit out there is 2/4, why does nobody make non-adjustable control arms that are already the correct length for a 4 inch rear drop? its obvious that the adjustably of the Spohn arms is a cool idea, the design is flawed...nobody want to make constant adjustments. Thoughts?
charonblk07
Calgary, Ab
F1-A forged 349ci
Nobody gets the same amount of drop with all the different kits available so having an adjustable set makes a lot more sense rather than being set with one length which would only fit one body size and drop kit. The problem with the Spohn arms is not the adjustabile portion, it's the end links that always need adjustment.
Reticle918
