I wonder how big a difference going from 2.8 to 2.1 on the bils would make in terms of ride quality, surely it would be less stiff
There are many misconceptions on how the 5100 shocks work. They don't achieve there lift by compressing the spring more than just moving it up on the shock body. They should and do pretty much ride the same no matter what setting they are on because the spring is always compressed to the same amount when it is supporting the weight of the truck. They simply move the spring location by raising the lower spring perch on the shock which makes the truck ride higher. You do need to compress the spring more to initially install it on the shock because the spring is not supporting the weight of the truck so the shock is fully extended and is the limiting factor and holds the spring back. When the truck is on the ground the spring compresses to support the truck. The shock is no longer holding the spring back. It is floating within the spring. The ride height is higher because the spring is mounted higher on the shock. I have never seen a post where someone had a issue with the ride after installing the Bilsteins that didn't turn out to be an oversight or mistake during instalation.
To the contrary perfectly supports my definition of how the Bilstein shock works. A leveling spacer actually moves the upper shock away from the upper shock mount. This completely changes your suspension geometry and allows the shock to move way past it's recommended downward motion. It also causes the spring to be closer to coil bind upon compression which can result in a rougher ride. Due to the fact that your suspension is not traveling within its design parameters you can have upper ball joint failures and even CV issues in some cases. The leveling spacer in the Bilstein shock are two completely different methods of raising the vehicle. Look at it this way, let's say you wanted to put your truck up on blocks to do some work and you decided you would put it on 12" blocks. It's going to take a certain amount of energy to hold that truck up that the blocks will absorb. After you work on it awhile you realize it's not high enough so you decide to put for more 12" blocks under the truck. The truck is going to be 12 inches higher but it's not going to take any more energy to hold the truck 24" off the ground then it did to hold it 12" off the ground. This is exactly how the Bilstein shock works it simply moves to spring up on the shock body to lift a truck higher there's no more energy put on the spring to hold the truck higher. There are several videos plus the Bilstein website that probably explain it a lot better than I do maybe I'm just not explaining it clearly.
If your ride is rough to the point you'd call it rough after a bilstien 5100 install at any setting to include + 2.8" , then I'd be looking at the installation for something being incorrect.
Or a lot less likely a defected new shock assy .
Thing is , we've seen countless improperly installed bilstein 5100s from DIY guys and professional service shops .
There's 4 main points on the install
1) install the spring seat right side up .
2) install the supplied washer below the dust cover on the piston Shaft , NOT in direct contact with the supplied top nut .
3) Torquing of the top nut IS required
4 put everything back together properly & get an alignment.
Sent from my SM-G900V using Tapatalk
It was needing to torque the top nut. Should I get another alignment now that everything is back tight?
I agree with Dan , but I'd pay attention to the ride ...ie pulling one way over the other in normal driving conditions. ...if it seems off one way or another then an alignment may not be a bad ideaI dont think you need an alignment. You just tightened it down but did not change any angles or remove the parts of the suspension that keeps your truck in line.
Good job on figuring it out and hopefully that solves your problems! If not, you know where to ask![]()
I did the Bilstein adjustable 6112 coilovers in the front of my truck with Fox 2.0s in the rear. Both are beefier shocks (larger diameter) than the stock shocks and I can definitely feel my ride has been much smoother. I also upgraded my upper control arms because of the dreaded ball joints popping out on the 1500's.
My intentions for the new shocks were to mildly lift my truck 2.5" in the front as I've heard leveling kits can be to the detriment of the front suspension components and to compliment my 1" rear spacer with an appropriately sized shock (fox is rated for a 1" rear lift).
I avoided the Bilstein 5100's because I have read they give you a harsher ride which I absolutely wasn't looking for as well as the fact that I have no intentions of off-roading and didn't want to sacrifice ride quality for performance.
From my research, basically every other brand of truck sees an improvement in ride quality from the 5100's except the Ram due to the fact that our trucks come from the factory with a plush coil over system.
My shocks haven't changed from what I can tell over the last 5,000 miles. The day I had them installed them until now I would have to say the ride quality has stayed the same. As far as the compression of the Bilsteins I really don't have any answer to that as I didn't install mine myself.
Good luck with everything!
What part number are your 6112's and what setting did you use?
34 foot lbsWhat is the torque spec on the top nut?
Sent from my SM-G935V using Tapatalk
Thanks34 foot lbs
