Running Hot
Gousha
Kansas
I have a 2011 Ram 1500 4wd with a 5.7 hemi, it ran hot the other day while idling with AC on at a store (99 degrees outside). Cooled down added water and drove home. I think thermostat might have stuck. Since that time the temp gauge has ran a few degrees hotter and if idle for longer than 5 to 10 seconds temp begins to climb again. Am I dealing with a thermostat issue or a water pump issue? I have not found any leaks anywhere but water level seems to decline. Or is smething else going on here?
Thanks in advance to your replies.
G
Gousha
Kansas
Anyone care to share thoughts
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
The thermostat is so quick and easy to change on these trucks that I would start there. You won't even lose a gallon of coolant swapping it out.
Check if the fans are in working order too and go from there.
How many miles on the truck now?
G
Gousha
Kansas
172,000. Purchased used, so I am not sure about the age of parts
rzr6-4
nebraska
'09 2500
Thermostat is definitely the easy and cheaper option so a good start.
Mine would do the same thing and it was in fact a bad water pump, so it wouldn't surprise me if you end up having to do that as well. If you have to get a new pump, buy OEM.
CanuckRam1313
Ontario Canada
2023 Warlock
Definitely OEM water pump is the way to go.
Perhaps also look at putting in a 190 deg t-stat, too.
If there is a bleeder/air hole on the t-stat flange, make sure to index it in the 12-o'clock position when installing.
Treburkulosis
Glorified Car Washer
Haslet, TX
Mine just started this. 160k. I started with adding Kool it to the system. Its helped, but it needs all of its cooling system freshened up.
RamCares
n/a
n/a
Hello Gousha,
Our team would like to apologize for your trouble. We would also suggesting seeking a diagnosis from one of our authorized dealers for a solutions to your concern.
Naudia
Ram Cares
