Rust...
Rijrnnr
Raleigh, nc
You can see the spot welds where the rust is in those pictures
Once you take out the plastic wheel well liners , you will see the inner rear quarter support that is spot welded to the bedside on both sides
Spray inside that support from the backside thru the open spaces with fluid film and plastic wands , spray the hell out of it between the support structure and bedside
It will drip down and coat the areas you can’t reach
Helps to remove the rear tires and jack up the frame
You will see once everything is removed
Start there first
My 2011 is spotless and I live in WI
Rijrnnr
Raleigh, nc
Something called "fluid film" was mentioned twice in this thread. Sounds like I need to get some. What is it?
tomb
ontario canada
2012 bighorn-cherry red
I have it in the same spot plus the bottom edge of the tailgate. I had the hood replaced under warranty before it ran out.
2013 RAM 1500 SLT 110K KMS
the hood is aluminum-atleast mine is-why would that need to be replaced?DSC00560.JPG
tomb
ontario canada
Fluid film is great for rust protection-just dont spray it near rubber boots or seals-it will swell the rubber
Brandon-w
Yukon
2015 Ram 1500
Acf 50 is a great corrosion and rust preventative. We use it on aircraft.
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
493mike
mid Michigan
V-10
I wonder if I can claim a tax deduction in Michigan for the cost of a case of Fluid Film?
Mike
