sagging park brake cable
Flhfxd
I took a quick look at my sagging park brake cable. It does not appear that I would have enough travel on the mid length adjuster to elevate it back into proper position. As most of these types of items are "known", I figured I'd ask here first before I crawl under.
2014 Ram 1500 4x4 Crew
Thanks for suggestions
Edit: should have added the park brake functions normally but the cable is sagging way too low
chrism1367
Believe you're going to have to adjust from the rear brake adjuster inside the rotor. I have the exact same problem. Dealer said they adjusted it and it's good to go but I believe parking g brake is sticking and caused it to rub on rotors and now rear rotors are warped
charonblk07
Calgary, Ab
F1-A forged 349ci
First, at the axle, make sure the park brake level is fully retracted, whack it with a hammer and punch to make sure it's all the way to the rear since it's very common for them to either stick/seize or just rust about halfway between. Use some penetrating oil first to try and break any rust up.
sticknstring
On my 2013 quad cab 1500 it did the same thing. I just adjusted it there below the cab and it tightened right up
cbsmith
New Brunswick, Canada
2014 Ram 1500 Outdoorsman
Mine did this last year and it was frozen parking brake arms on the brakes. The dealer freed them up and it worked fine. It is starting to sag again and I am going to take a look myself.
I have read a number of posts, and the dealer also said, don't adjust the slack adjuster under the truck, it is for balancing left and right. The proper way to tighten up the cable is by using the adjusters in the back brakes.
smoothee
St. John's, NL
This right here. Had to do this to mine recently. Then throw some high temp lithium on there.
F
Flhfxd
Hey Smoothee, coincidence....I'm from "Town" as well!
Will crawl under today and take a peek. Will also try to post a pic.
smoothee
St. John's, NL
Lol, small world!
Everything will eventually seize around here it seems. Even though I was using the parking brake everyday.
F
Flhfxd
How do you upload pics?
F
Flhfxd
Hope this works
JJP71584
Pgh, PA
yeah my '12 looked exactly the same, tried to adjust it but it wouldn't move, dealer wanted $400 to fix it...no thanks. I zip tied it up under the truck so I can't see it. Still works fine
F
Flhfxd
OK. You guys were right on the money......levers at the brake were not retracted. Persuaded them back into position with a hammer and the cable raised right up again. However, as I did initially try to adjust slack out of the cable at the mid-adjuster, and it is now at the end of it's threaded travel, I suspect that if I were to loosen it then tap those levers a bit more, the cable would probably tighten up properly. I believe the mid-adjuster is in fact a balancer for right / left brake as the cables split right there and are obviously of different length. The longer one being the hardest to "re-set" as you would expect. Geez, sorry that was wordy....but I think you can get it. Just a PITA issue.
Thanks again :favorites13: on me
marathonsp10
2014 CC
I had the same problem, took it to dealer for warranty work and had them check as well. parking brake was seized on both side full new assemblies covered under warranty only 30k miles on it.
F
Flhfxd
Shyt design, I allow. And I've been a good boy all along makin sure to set thepark brake daily so as to keep it exercised and in proper working order.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
They really are a crappy design I tightened mine with the cable and it then wore out the shoes inside. I should probably fix but don't care as long as it works when applied and my rear brakes still work I am happy.
Hemi395
Cape Cod MA
I hit the parking brake linkage on the back of the backing plates with Fluid Film every fall. This helps to keep them from rusting and lubricates the linkage.
F
Flhfxd
And here we go again. Lubed and cycled several times.
O.R.T.
Wessyyydddeee
^Time to throw the rear on jackstands, pull the wheels and the rotors and look closer.
glsander
