Seal Power hemi Lifters anyone used them?
Rwitt18
Arkansas
Got a set of sealed power 5.7 hemi lifters in gen 4 hemi seam good and quite. Looking to see how long they last compared to oem.
HEMIYEAH
Georgia
Rwitt18, any update on the Sealed Power lifters, are they still running good and quiet?
You used the HT-2311k and HT-2312k sets to keep the MDS, correct?
Any update on this? Originals are sometimes a bit hard to obtain, not to mention their price. And I know Enginetech are to be avoided.
The OP hasn't been back since Jan 4th,hopefully he pops in and updates us,as i'm also curious on how they're holding up
sparkybg
Sofia, Bulgaria
Got one MDS set from Rockauto, spend 2 days taking the head off, cleaning, preparing, milling the exhaust manifold (was 0.75mm up at both ends, but there were no broken manifold bolts) and putting it all together just to find out that on a hot engine one or more of the new lifters makes much worse noise than the old one.
AVOID THIS CRAP!!! I will return them for refund, but noone will refund me a weekend spent replacing them with perfect weather for much more pleasant things to do.
Ken226
Washington State
That's a bummer.
We should petition Johnson to make MDS lifters.
This lifter thing is stupid! I built the engine that's in my boat in 2010, using a 150,000 mile Chevy L98, from an 87 IROC Z camaro, converted to a 383 stroker with a comp cams 264H roller cam. The OEM chevy roller lifters had 150,000 miles on them when I built that engine 15 years ago. I've been using it in a marine environment for 15 years. The lifters have been completely trouble free. Once, the Holley fuel pump **** the bed about 30 miles out from San Diego bay, but I had a spare onboard and swapped it out in 20 minutes, but other than that it has been trouble free.
I wonder if the Johnson non MDS lifters are as reliable as the old school L98 lifters.
It sucks that you can't disable MDS in AlphaOBD.
sparkybg
Sofia, Bulgaria
Disabling MDS is done with flash reprogramming. AlfaOBD (and JScan) are just OBDII Scanners/Configurators, and they will bever be.
I can disable my MDS (in fact in the moment it is disabled because there was a lifter that was ticking for 5-10 seconds on hot restart after shoft pause and I decided to disable it until I repair it), but I think this won't make the lifters trouble free. As far as I know the MDS lifters are not significantly more troublesome than non-MDS ones.
There's non MDS set of lifters from Melling, which I believe is a good quality one. But it costs more than full set (16 lifters) MDS OEM Lifters.
I am repairing only my vehice. I don't have large database of failures and non-failures to make decisions based on it. The only thing I made after I bough my vehicle is to fit high-volume oil pump from Hellcat, check and replace the connectiong rod bearings (although thr old ones were OK), and thats all. This brought my idle oil pressure 25% up, compared to stock pump.
My vehicle is only 219k km (136k miles), which a bit early for lifter troubles, but that's the way it is.
P.S: I bought one set (4 lifters) non-OEM lifteers just because there was only one OEM set available from Rockauto, and I needed 2. The stupid thing is... a day after I ordered it, there were more OEM available. :) I am from Europe, so I don't have much places I can buy from. I order 99%$ of my parts from Rockauto, because the shipping there is ridicuously cheap and trouble free.
That's a bummer.
Little tidbit for you,there's actually more oil supplied to the lifter galleys when the engines in MDS mode. Takes oil pressure to push the pins in so the lifters collasp,when you disable MDS there's less oil to the lifter bores. BTW when you're pushing the Johnsons,you should also be pushing a high volumn oil pump,the stock pump doesn't supply enough volumn to offset the internal oil leak the Johnsons create
Spend 16 minutes and watch this video right to the end,he also shows the MDS delete plugs you should install when you do a MDS delete cam.
That's a bummer.
Ken you might also want to read this article to.
Ken226
Washington State
Yes, i remember that video. I've seen it a few times. And the MMX article too.
When I mentioned disabling MDS, I was thinking along the lines of a MDS delete, with the solenoid plugs, Johnson lifters, Hi volume pump and everything.
As stupid as this is going to sound, the only thing about the MDS delete that I have a hard time with is using a Tuner to disable MDS. I've always had an aversion to those things. If it were possible to just turn it off via AlphaOBD, i could talk myself into it pretty easy.
So far my engine runs perfectly and quietly. If and when the cam get wiped, i'll go with OEM mds lifters and cam since there isn't a way to do a MDS delete without the tuner.
You're 13 is easy to tune,it's not till 2015 that they started to get harder to tune.You're 13 doesn't need an unlocked pcm
MMX sells a no tune cam,if you haven't checked out their cam selections yet.
Ken226
Washington State
Hmm, well in that case, i think maybe i'll keep this truck forever. If/when the cam ***** the bed, ill go non MDS with MMX Cam and Mopar delete kit. The Diablo Tuner seems easy to use according to some youtube videos.
Or, maybe i'll get lucky like my nephew.
I have a nephew who got his first truck at age 17, about 5 years ago. Being a kid with no money, and very entry level low paying jobs, what he could afford in a truck wasn't much.
He got a 2009 Ram 5.7 with 250,000 miles. It was a farm truck, covered with dents, rust, the tailgate bashed in, and an absurd amount of idle hours. He changed the oil every 3000-5000 miles with whatever oil and filters wal-mart had on sale, and somehow is still driving it at over 300,000.
Yet, on this site you see a new cam failure thread every other day, at much lower mileage, and from guys who use top tier oil, filters, additives, etc etc. :33:
Beaters never Die ;) :Big Laugh:
