Service Airbag System
ram1500rsm
Trabuco Canyon, CA
2014 RAM 1500 Crew cab 4x4, the message came out in the dash today.
So far i've checked the gray connectors under the seats to make sure they were not loose, i even unpluged/plugged them back. Changed fuses i think #85 and 86 if i remember correctly in the fuse box, don't think i needed to do that but what that heck fuses are cheap. Ligth is till on and stays on.
I haven't unplugged/plugged the yellow connectors under the seat cause i don't know if i'm supposed to do so without causing any issues ?
I hooked up alphaobd and read all faults connected to the occupant restraint module (airbag) and it came up with B0001 and B0002
54017835634_4684a543e8_k.jpgScreenshot_20240923_175210_AlfaOBD by RAM RSM, on Flickr
54017834099_004906cf26_k.jpgScreenshot_20240923_175217_AlfaOBD by RAM RSM, on Flickr
Just for the record you can unplug the yellow connectors ,all it'll do,is make the dash tell you,you have an issue with the airbags,as soon as you plug them back together,the dash will go back to normal.
Lots of us remove the seats for drag racing.
Ron Silva makes a bypass connector for the cars,that supposedly works on the trucks too,that'll keep the dash happy,if you wanted to permently remove a seat.Similiar to the Challengers that can be ordered as a "seat delete" car. On the Demons and 1320's the passenger seat and rear seat are actual options,that are a $1.00 option if you want them.
If you look at the 1320 Drag Pack options,you can see where the seat deletes are mentioned
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I was al ittle scared until i found some videos about removing the front seat. so i disconnected the + battery terminal and unplugged those yellow connectors, sprayed QD contact cleaner and waited like 10 min before i plugged everything back. Service airbag system message is still on :(
I'm trying to see what else can i disconnect/do before having to resort to go to the stealer. I don't think a regular shop can fix issues with with the air bag system? i hate the dealer may want an arm and a leg to fix this chit up.
i've messed with the little grey plugs and yellow plugs under the seats. haven't touched the other 2 grey ones under th drive seat, unplugged, sprayed qd contact cleaner and plugged back, also changed the 2 fuses in the fuse box. Until yesterday i didn't know micro fuses existed :)
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
My money is on the clock spring
Had this happen when I first bought my truck mew in 2013 and less then 1000 miles on it.
would randomly come and go
was a clock spring
jr27236
New York
Did you not read my reply?? Guarantee thats your issue.
zrock
canada
I guess it depends on how much you value your live and your passenger's life. Im quite happy and capable to pull wrenches on my own veh but the airbag system is something i will not touch i leave that to the people that are trained to deal with them.
Jeepwalker
WI
2012 Reg Cab, 4x4
Do a google search. Most posts point to the clockspring. But of course like anything, you might not know for SURE until it's replaced. Sometimes a fault can be caused by multiple things (wiring, item, connector, etc).
jr27236
New York
I didn’t see it until now. Did you do this yourself? I’ll start making some phone calls to local shops and see how much they charge for the job.
I dont know how mechanically inclined you are but the job is not that hard. Tou can do a youtube search and find a video and youll be fine.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Yep i've been watching some videos in youtube and i think i can do this. i don't have the steering wheel puller but i've seen it can be done without it.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Runing a search in the Mopar online stores this is the part number that i think should be the clock spring: Mopar 68528301AA
Non Mopar:
Standard CSP322 (non heated steering wheel)
Standard CSP323 (heated steering wheel)
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
When I did mine, I bought a cheap amazon puller. I got mine from the wreckers after I saw what dodge wanted for it.
good luck :cheers:
I've seen one in Ebay for $100 but it says it doesn't come with the angle sensor ? This is the description
Product Name: Clock Spring
Quantity:1pc
Clockspring Comes without Angle Sensor
For Some reason ,we did not display the part number ,you can message us if you need .
PART NUMBER: 68110740AB, 68110740AE, 68110740AD, 68110740AC, 68459549AA, 68528301AA
Compatibility / Fitment:
With Heated Steering Wheel,Comes without Angle Sensor need to use your old one
RAM 1500 2013-2022
RAM 2500 2013-2018
RAM 3500 2013-2018
RAM Laramie 2019
We guarantee that the clockspring is not a recalled product and will be transported according to the requirements for transportation.and this product is not dangerous item.
Note: Please send me your Vehicle VIN# (if you can not confirm it)
to verify this is the correct part for your vehicles before we can ship)
Note: if the original part have grey-White Plug ,
It is an optional part and not included in our replacement part
Remove it and install it in the new part at the same location
Please double check the photos
a) Direct-fit replacement electrically operated switch that replaces damaged OE units increasing road safety and restoring steering wheel function
b) Engineered using copper alloy conductors ensuring superior electrical conductivity with low resistive losses
c)Feature a robust design with high grade materials to meet the stringent demands of today's service professional
d)Made to OE spec to ensure proper fit, form and function
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Ordered the clockspring today from this company, i sent them the truck vin number and they sent me the link below. I'd think i'll have the part in my garage before the coming weekend. Never done this before so hoping it won't be too dificult to replace
Also ordered this steering wheel puller
and airbag remover tool
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Well i got the part yesterday and openened it today, lucky me the damn thing comes with a piece of paper that says, Important do not install, read first
It doesn't come with the angle sensor. before i ask for a return, is this something easy to replace ? in all the videos i looked i don't see anything remotely close to what those tiny pics show as angle sensor and i looked online and this stupid thing is one of those POS where there is nothing out there showing what it is or how to replace.
54076459546_17a703be1f_o.jpg20241018_141020 by RAM RSM, on Flickr
mrack
How does one go about centering a used clock spring? I have the same airbag codes in my 09 SLT, planning on stealing the heated wheel and clockspring out of my 2010 Laramie. Hopefully the 09 has the heated wheel wiring
Ken226
Washington State
Are you certain that your truck has a steering angle sensor there? Mine is a 2013, and when I look at the diagrams on MoparPartsGiant, it only shows the clock spring.
And If I remember right, when I replaced my electronic power steering rack/pinion, it had the steering angle sensor built into the steering rack.
Your 2014 should have the EPS as well. So, is it only the 2012 and older with hydraulic power steering, that had a steering angle sensor in the column?
KAKA
