Service transmission continue in d
Ricardo1405
Tulsa
So I have a 14 ram 1500 with the 8 speed. Today while driving it started freaking out blinking the tire pressure light and a quick message that would say service transmission. Continue to d. Or something like that and it flash super quick sometimes stay for a second then go away with an anoying ding constantly. Drives just fine though any idea
RamCares
n/a
n/a
Hi @Ricardo1405 - We certainly understand why this would be concerning. If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be more than happy to provide you with an additional layer of support for the dealer process.
Mark
RamCares
Shawn226
Mercer County, Pennsylvania
3.0L EcoDiesel
are you sure it’s saying service transmission? Or service tire pressure monitor system. Because if your tire lights blinking, it will send that message to the touch screen, but never have I seen one about the transmission while flashing a tire light.
Iceclimber
Washington
Ecodiesel
I had that issue. The stealer made many attempt to fix it and then I finally did. There is a big electrical connector under the drivers seat region that is likely causing this behavior. You can take it apart, check for corrosion etc. then use dielectric grease on it. You want to be really careful as this particular connector is fragile and it's easy to break the locking clip. I then zip tied the connector and traded the truck in haha. However that issue never reappeared.
https://www.ram1500diesel.com/threa...do-not-shift-until-u-reach-destination.65728/
This may help you.
