- Jan 16, 2012
- 16,061
- 23,908
- Location
- Cedar Creek, Tx
- 2015
- 5.7 Hemi
Where are you located...
Just east of Austin Tx
Jay
Let me know where you end up getting your shorties... Im shopping around now. I figure with the MA inspections .. LTs arent worth the risk. I just posted this for everyone else opinion.I'm in MA as well and from what I've heard if you get long tubes you may not pass smog, even if you put cats on. They look for the factory cats.
I'm looking at headers as well but am likely going to go with JBA silver ceramic shorties to be safe.
Give Matt @ Moe's a call. That's what I did. I think I got JBAs in stainless. My dealership put them on.
Shortys were the right choice for me. I don't race. They're simple and realitivly inexpensive. I'll never have a broken bolt/leaky manifold. They'll pass any inspection anywhere. My truck can be sold in any state. +8HP, I'll take that!
On Hookers website their shorty headers for our trucks look like stock manifold but in stainless steel. They would eliminate any future bolt issues over stock, but I wonder if there would be even 5 hp with them?? Doubt it. Probably easiest to change out over all aftermarket headers, they are like logs, no tubes all over. At least they are kinda cheap too. Guess just for bolt issues with these.
When mine breaks I’m going t do Jeep srt8 manifolds- they area an exact replacement for our manifold plus they r cheap
Depends if you actually want any noticeable performance gains. My understanding is that the vast majority of people that put shorties on looking for gains regret not going LTs.
I've got JBA LT and have no issues with brake line proximity. Lines can always be wrapped and/or pushed out of the way. I think I've only seen one, MAYBE two people on here that were concerned with brake line proximity, but were able to figure something out.
What's the difference between LT headers and shorties??
Ohhh okThe Jeep SRT manifolds do bolt up to the heads but dont line up with the y pipe. The y pipe will need to be reworked to line up with the SRT manifolds. Not horrible but not an exact replacement
Awewome info, thank you. Will be shopping for shorties today.Very hard to find any real good info on headers any more. Everyone talks about LT vs shorty and no one talks about What size Primary pipes the headers are!
LT vs shorty;
Put the Correct shorty's on and you will increase performance > the Wrong size LT's!
Dial in the correct LT's and you will have max gains right where you want them according to your build goals.
Street/ tow vehicle
Wkd warrior
All out Race truck.
This illustration is the simplest explanation of the difference in header designs.
If your truck is a daily driver and you want to improve its drivability with added low end TQ plus added HP you would be looking for a shorty with 1 1/2" primary's and no greater than 1 5/8". Any larger than that and you will begin to lose bottom end as the primary size begins to move the power curve up and beyond your normal operating window.
I believe the best header Period, would be LT's with the first 8" 1 1/2" then 1 5/8 the rest of the way. This for a non internally modded 5.7l daily driver/ tow vehicle.
Since those are not available, 1 5/8" LT's would be the next best thing for over all performance gains on a stock longblock 5.7l. (Original MP LT's are 1 5/8") 1 3/4" will work, but are already to large and you will get more gain higher up where they will be of seldom good use. 1 7/8 are All out 600+HP Race headers and should only be used for larger displacement engines, supercharged applications or highly modded (Cam/Heads/ect) engines.
Should also mention that anything larger than 2 1/2" midpipes will again, move the powerband higher and rob valuable TQ where you need it most.
So when asking what header to run, you really need to ask yourself what you want to use your truck for?
Once you've answered that Q, then choosing the correct set of headers becomes easier.
With all of the larger LT's out there, it's getting harder to find a good set of LT's for a daily driver, so the 1 5/8" shorty's or 1 1/2" if you can find them are the better choice
