The hippie
- Apr 10, 2015
- 95
- 3
- 2015
- cummins
Since the F250 has 930 foot pounds of torque does it tow more than the ram Cummins 2500?
So now you can dig up the Ford specs, check those numbers and see which one has the bigger difference.
Depending on cab and trim its within the same numbers. The 250 is rated for a conventional trailer of 18000. Thats best case with all proper packaging. Really the differences between all big 3 are a few hundred pounds when spec'd out.
Agree with you except for they shouldn’t pull as much as they’re rated for. That’s what they have ratings. The truck can handle what it’s rated forA 3/4 ton should never pull as much as they are rated. The trucks are not heavy enough for a 9 ton trailer.
Also the Cummins and the Powerstroke are 2 very different motors. The cummins is a slow churn down low torque machine, the powerstroke is a high rev motor. They work, feel, drive, operate, very differently.
If I were buying a 3/4 ton I would get the Ford as untrailerd or only a weekend tow rig they are frigin rocket ships, fast and powerful. If I were pulling 15000 lbs daily Id get a cummins as they have better low end grunt to get things moving and chug along at low rpms.
I thought diesels (like the power stroke) are low REv MotorA 3/4 ton should never pull as much as they are rated. The trucks are not heavy enough for a 9 ton trailer.
Why was your truck totaled?Yeah, they are. I looked at all of them when my 2014 2500 was totaled. I noted the specs were so close that it came down to which one I liked the best from an appearance, option and driving perspective. I chose Ram...again... and couldn't be happier with the truck.
@MADDOG , I wanna everytime I see this. You must have been an emotional wreck.
Wait... how did this thread find its way to 5th Gen??
Love that Harvester Blue. Retro.These guys have some great comparison videos of all the HD trucks. They run a variety of towing tests with them. Here is just one on efficiency but they have other on max capacity etc if you search their channel. Good stuff.
A ZF eight speed is rumored to becoming to the HD trucks including the CTD.Only benefits to the ford over the ram 2500 is the 2500 you get the 68rfe vs Ford 6r140. Ram gets reduced power but still 800 ft lbs of torque isn’t bad considering they all max out on towing 17k to 18k w reg cabs. 3500 is where you get the big boy Aisin trans and the most torque.
