Smoke???
bigblock79
4.7L
2002 4.7L smoke black, thought about putting a Cummins sticker on my rear window since it smoke soo bad when i punch it. it running really rich, the cat was removed and the O2 sensors arent reading, would that cause the smoke and the MAJOR drop in my gas mileage? averaging 6mpg...
02 Ram
Nashville TN, soon back to IL
2005 NSRT-4
2.4L Turbo
Yes, the o2 gives feedback to the ECU to control fuel. That is causing it to run rich. The black smoke is fuel and since its running rich, yes you are going to see crap mileage
ercmesser
Tampa, Fl
Had the same problem replaced upstream o2s and problem solved
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Check your oil for gas contamination, you maybe washing your cylinders. You need the front O2s looked at. What codes are you throwing?
Redtruck-VA
Virginia
Your codes cover a variety of voltage related issues. I would check grounds and battery. Charge it overnight and measure the standing voltage, it should be 13.8vdc.
