So what you're choice of oil?
tidefan1967
Summerville, South Carolina
I use Supertec synthetic 0w-20 with a high quality filter and change oil at about 70 percent of the life being used on the computer. The 0W on the bottom does way more than one would think for flow at cold weather starting. I think that causes the oil to thin out a bit earlier, hence changing it at 70 percent used, vice 100 percent.
Your sig says you've got a 6.4 Hemi. Why would you use 0W20 in a 6.4? Even the recommended 0W40 is too thin in my opinion.
cash4acres
4lb pompano
6.7L,660ftLbs=G56 Manual 6 speed
$20 a gallon Rotella t65-4 0 w. $60 a gallon Pennzoil Platinum Blue from gas derived product five weight 60 weight oil for Lamborghinis McLaren's Bugattis Ferraris c8s.
njjeff201
Sparta, NJ
5.7 E Torque Hemi
My Longhorn is a few months old... 800 miles but when the time comes it's getting watz in the manual SAE 5W-20 FCA Material Standard MS-6395 such as Mopar. Pennzoil or Shell Helix. Specs are on oil filler cap guys. Oil filters such as Mopar must meet or exceed SAE/USCAR-36 performance requirements.
Octane
U S.A.
The owners manual is a book on planned obsolescence.I plan on my own plan,as I is The man wid da plan.Engineers can always say"it works on paper".
Agcat
