SPACER LEVEL KIT = STAR case 2014 Ram
Djeazie
2013 Sport
Yup set at 1.4"
Sent from my SCH-I535 using Tapatalk
yodge
Huntington Beach CA
2013 ram 1500 hemi
ImageUploadedByTapatalk1395716478.081194.jpgImageUploadedByTapatalk1395716487.598206.jpg
Does anyone know what this is? It looks like a spring coming out of my upper control arm where it meets the spindle
O.R.T.
Wessyyydddeee
Yep, inset snap ring for the lower portion of the ball joint. Get it reinstalled ASAP.
yodge
Huntington Beach CA
2013 ram 1500 hemi
Something that can be fixed by the shop who installed it or do I have to contact icon ?
BMD
2015 x1 and 2014 x2
I am doing my daughters truck with the rancho loaded I assume I could have same issue?
Arctic-Rodz
RGV, TX
6.7L Cummins
is this for level only guys or does this problem come up when you put a spacer on an existing lift or other lift component.
ive heard you can have problems if, for example, run the 5100 AND a lift spacer.
been running my 2.5" HBS for several thousand miles on my 2013 4x4 and with no problems.
any signs of issues I should look out for?
yodge
Huntington Beach CA
2013 ram 1500 hemi
Got icon on the phone and it is a spiral lock. He said it happens sometimes all I need to do is jack the truck up and push it back in. Thankful it's just that. Nothing is usually that simple with dodges
11BPSMIKE
Quispamsis NB
Check the top of the upper ball joint closest to the tire to see if the lip is raised out of the control arm. Everyone I have looked at is doing it.
11BPSMIKE
Quispamsis NB
Ive been running my Zone uppers on my '14 with a 2 inch level for about 700 mikes now. No issues
During the install, it was clear the Zone balljoints have more than enough range of motion to avoid this issue.
Did you have any alignment issues with the zone control arms and HBS spacers?
oz97tj
None. Then again none of it is adjustable. Basically just the toe is set back to specs. Everything else was with factory ranges though after the parts were installed.
dirtridersr
sooo I read this thread before I leveled my ram I thought it wouldn't happen I don't beat on my truck and 2 weeks of street driving after leveling my ball joints are coming out, pretty pissed
yodge
Huntington Beach CA
2013 ram 1500 hemi
That's weird. I had my leveling kit in for over 4 months, frequently off-road my truck and nothing happened until I combined the spacer with the spindle
yodge
Huntington Beach CA
2013 ram 1500 hemi
Mine is a 2.5" day star spacer
spade73
Edmonton
I'm having this same issue as well with my 2014 Big Horn. 2" Readylift.
L
Lobster Poutine
southern ontario
i just got my zone UCA's installed yesterday. ill be getting my allignment later this week.
install was one hour on the ground.
Djeazie
2013 Sport
Just had my Ram aligned after my lift install. Think I would have to have another alignment after installing the Zone arms? I would assume they wouldnt change anything or am I wrong?
