Spacers?..
draken
Vancouver, WA
Cummins
Hey guys,
To make a long story short, I want to have a little wider stance then i do currently. My set up is in my sig, but i have a Zone 6" lift with 5" rear. Bilsteins in front and 315/70/18 tires wrapped around 18x10 -24 motometals 967s.
Obvioulsy the route to go is BORA but I have never had wheel spacers and was was just wondeirng if their is a "right" one to get based on my set up or not.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
BORA spacers are definitely the ones to run if you do want some.... However they may not be the best option for your setup. How much wider are you looking to go? Anything smaller than a 1.5" spacer will require you to cut down the stock studs and IMO a 1.5" spacer is far too large for you to run with an 18x10 -24 offset wheel. They would essentially become a -62 offset wheel. For one that will be harder on the front hubs/bearings plus you will rub with a stance that wide.
My recommendation would be to get some 18x12 -44 offset wheels to achieve the wider stance.
