Sts turbo kit
808Donovan
missouri
has anyone tried the remote turbo kit from sts? was talking to the sales guys says $6400 for turbo kit, fuel system upgrade, intercooler, tuner, and turbo that supports 750hp. says base kit will produce 5 psi for 100-120 hp increase. these are the photos he sent me. what are your thoughts.
operator
Professional Firefighter Captain
Marrero, La
are these in production yet? id like to get one for my 2013rcsb ive been waiting for them to throw something out there for our trucks.
808Donovan
missouri
according to the general manager I was talking to Marc Michuad they are 09-13 ram 1500. was asking due to not seeing anything on their site but a few pics and a video of a pre-production kit. they do offer a 10% active military discount as well. [email protected] is what my emails say.
808Donovan
missouri
currently inquiring about a discount for a group buy, but is there an interest for the kit. asked for more photos/video, dyno sheets. what would be you additional concerns?
Sybil
Pretty cool! Does it retain the factory exhaust manifolds?
ericlee9386
I take it the flimsy duct coming from the turbo is the fresh air inlet? Besides that it looks like a cool start up kit
808Donovan
missouri
asked that this was his response a few days ago
Hello Donovan,
I recommend that you at least leave the factory exhaust manifolds in place. Headers will quickly dissipate heat which can make the turbo spool time slower. Typically we do not modify any of the exhaust components with our turbo system! Our system is even designed to work with the factory dual exhaust tips!
We would also be replacing your entire intake system with our charge tubes.
808Donovan
missouri
I was thinking the same about intake. was thinking of hard piping and where to run it too.
BlownGP
Houston/Baton Rouge
1. Google STS
2. Read Horror Stories
3. Run away
4. ?????
5. Profit
They have gotten better over the years with pipe sizing and reducing turbo lag.
Fact is still, a front mount turbo will be better.
A STS kit will be better than nothing and will show some significant horsepower gains.
Again, dont forget about the tranny..
2013blackram
Heard nothing but bad thinks with these guys.
On a different note procharger now has support for 2013 trucks.
ericlee9386
I would love a nice procharger setup. Just couldn't afford all the other stuff needed to run it at its best.
charonblk07
Calgary, Ab
F1-A forged 349ci
Because the STS turbos are below the sump oil level, they require a scavenger pump to pull the oil out of the turbo. Unless they have upgraded their pumps, they were the common failure point on these kits. When the oil stops flowing, it backs up into the housing, heats up, fries the bearings, and suddenly you have a toasted turbo. Even with a voltage warning indicator on the pump it doesn't take long to destroy the inducer. Now, there are oil-less turbos available now and since they aren't sitting right on the intake manifold they may last much longer in a remote application.
mattman_13
My luck I'd drag it off when I go offroading.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
All that can be mitigated by using a water/oil cooled turbo. My neighbor just did twin rear mounted turbo's on his C6 corvette. Switch to an electric water pump and e-fan. When you turn off the vehicle the pump and fan will still run for a couple minutes to cool the turbo down so you don't get coking from the oil.
hemihustlin
Montreal
Or a turbo timer lol? Or is is that just for mazda protegespeeds with a gready strapped underneath the steering collum cover or a 2012 tdi that wont ket you turn it off right away if youve been beating it and then decide to park.
Might be easier than changing the water pump but hey if you have crazy turbo setups you might as well have an electric water pump right!
KLRpanda
Personally you will be 100% happier with a front mount. I've got less than 4,000$ in my front mount build
WhiteExpress
Midland, TX
Remote mount turbos are a neat idea. But they're just a flawed design.
Lubrication is the largest flaw, but unnecessarily long boost pipes really hurt too.
KLRPanda has it right, you can find a good shop and fab up a proper turbo kit for the same amount, and have a quality install w/o all the failure points.
