Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
U&A
2016 3500 SRW
6.4 HEMI
Redline Dot4 for the win. That is what i used in my truck swear ta god. Pretty dang sure I gained some HP when i pour this liquid gold in there. And when i hit them breaks hard .....it messes with the earths rotation. Why else you thing the weather has been so strange this year...
And the ladies will naturally be more attached to you when they see you pumpin them Redline Powered breaks.
Shut randy!
Gotta go.....
https://www.redlineoil.com/rl-600
Sent while firmly grasping my redline lubed RAM [emoji231]
TXCOMT
Great Blackstone newsletter!
Highlights -
aint your daddy's atf, great article.
look at those low moly oils have massive potential fails.
one high moly oil failure, something small some copper line.
Hah! I was gonna post something about that newsletter too, especially the ATF fluid story!
TXCOMT
R.L.K.
Bristol , Tn.
Shut randy!
Gotta go.....
Your a NUT !!!
I LOVE IT [emoji106]
Hemi395
Cape Cod MA
Tell me what you guys think about this. Looks to me like the rear main seal is leaking. I happened to look under the truck and saw a drop of oil on the bottom of the trans. There’s also some on a wire harness and the starter is wet where it bolts to the block. I’m not thinking oil pan simply because the bolts aren’t and the bottom of the oil pan isn’t wet. Let me know what you guys think...5a556edec0a742f2219325ffe323cca6.jpga9863079ff6fcb1458bcfb51e073f915.jpg259a4ec390909d101417b9b36f8cdb3d.jpg11a661334094d614633e6b3167aa0747.jpg
Reactions: U&A
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
On my 1999 when the rear main was leaking it came straight down from between the engine and transmission. Oil was all over the transmission.
Really sorry to see this.
Burla
2010 Hemi Reg Cab 4x4
I think it is rare to have a rear main just start leaking without some rough ride or work. Last rear main I had leak the tranny was always soaked. it leaked for 8 years, didnt bother me much.
Burla
how many miles now on truck Corey. how many miles on new bills? nothing else new? that noise is gone now with new bar?
Hemi395
Cape Cod MA
So it's been damp in that area off and on for about 5 years now. I brought it into the dealer 3 times while it was under warranty and was told all 3 times that it's a "seep not a leak". Well now at 58k it's a leak. I'm assuming it's the rear main seal but it could be something else too. I was really hoping it was the crankshaft position sensor leaking but that was dry....
I've got about 2000 miles on the Bils and since I replaced the sway bar end links that noise is gone...
AFMoulton
Nuevo Mexico
It’s part of the power train so you should have 5 years/60,000 miles on that. Depending on your time line you might still have warranty on that.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Arsenal 18x9 +12mm
Cooper St MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Redline 5W-30 RP 10-48
1996 Nissan Altima 2.4 Amsoil SS 5W-30
U&A
2016 3500 SRW
6.4 HEMI
Without seeing it in person I do believe it is your rear main seal.
What I would do first off is clean the **** out of that area and try and degrease it the absolute best you can and see how fast that leak is.
I know some people will just ride it out and deal with it but honestly I would get that fixed if it was my truck.
This sucks man. You should stop over so we can have a beer and talk about it[emoji41]
Hemi395
Cape Cod MA
It's 2013 so that ran out in March of 2018[emoji3525]
Hemi395
Cape Cod MA
Sounds good to me[emoji16]
AFMoulton
Nuevo Mexico
Damn
Burla
Yeah, goes back to what I was saying about rear mains usually don't just show up and what dealers say when confronted with seal leak, lol. It was 600 bucks to fix mine they obviously have to drop tranny, so I just let it leak. In your case it probably was never a good connection, in my case it was after some tranny work. It never amounted to much in my case but a few drops. Nothng you can really do unless you feel like paying out 600. Kinda watch it.
Burla
See what tranny bolts you can access, maybe make sure they are all torqued.
Burla
Not to rub salt on it, but it is at least possible that the additional travel of you front end is making it worse. That is why on anything I like to see what work was recently done. When you hit the brakes and your front end travels 3 inches more, it "can" jar some things awry even seals. That clunk happened after the bills, you figured that out, but also it is "possible" the extra travel is what opened that leak up. Maybe good maybe bad, good if you can find it and fix it. My guess would be a lot of people wont believe that, but I've seen some stuff in my day I tell ya. Lifts lead to things one wouldn't expect and I've seen my share, always being around the 4x4 crowd 30 plus years.
