Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 237 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,780
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
This brings back memories - Fleetguard developed a duplex oil filter that was part bypass and part full flow. Not sure if they make one for little engines (like Ram 6B6.7), but we rolled it out on our 1st Cummins QSK60 engine....a V16 with 3,000 horsepower. Might check this out for Ram.
U&A
2016 3500 SRW
6.4 HEMI
We have seem that. Great filter option. I think we found there is not a good option for the rams if I remember right.
Sent while firmly grasping my Redline lubed Ram [emoji231]
HEMIMANN
Minneapolis, MN
Sure there is - I used one back in '91-'99 on my original 6B5.9T engine. Here.......
https://puredieselpower.com/product...etguard-venturi-combo-oil-filter-lf9691a.html
Fleetguard LF9691A. Or Amazon, or wherever.
Or not - Fleetguard page runs up to 2015 with different LF filter number. The above info is a re-seller. Advise anyone to just call a Cummins Distributor.
Equipment Details
Export As…
Part Number Manufacturer Fleetguard Part Number Description Parts required
4947561 CUMMINS FS43255 FS_Filter in Filter
UPGRADE with FS53000 1
4936636 CUMMINS CV52001 Crankcase Ventilation 1
- - MK14213 Maintenance Kit 1
4920070 CUMMINS LF16035 Lube 1
53034051AB CHRYSLER AF27684 Air Filter - Panel 1
3949561 CUMMINS LF3972 Lube, Full-Flow Spin-On
UPGRADE with LF16035 1
5260529 CUMMINS FS53000 Fuel/Water Separator 1
  • Fleetguard ApplicationSearchResult - 2015 Ram.pdf
tfeni52355
Indian Land, SC
2016 Longhorn
5.7 Hemi, 4x4, Air Suspension
Now, maybe every hemi should have one of these anyhow? High Pressure oil pumps as opposed to high volume like rick aka wild boy suggests.
Would there be issues with other parts of engine having seal problems with 75 PSI oil pressure? Seems it would sure find the weak spots in a hurry! :)
U&A
2016 3500 SRW
6.4 HEMI
Well i feel I can confidently say that the Redline 5W30 seem to make my Engine QUIETER than Redline 5W40. Engine is still way quieter on redline than on any other oil brand I’ve tried but I’m just being honest.
I think some guys starting last year or two have felt the same way, that even finding the correct redline for any engine can be a process, but it is the brand keeping most hemi's the quietest. 5w30 for hemi 6.4 seams a good choice, 0w30 is more popular then ever 5.7 in cold places benefiting guys even at 30-40f. Find something that sticks and ride it till it don't. For guys in warm places start thick and move down if needed, 5w30 for me thick for 5.7. For people in the cold, start thin and move thick, 0w30 likely is the choice.
Hemi395
Cape Cod MA
This is great info Kyle[emoji106]
So it appears RL 5w30 is Hemi Honey for the 6.4 as well...
U&A
2016 3500 SRW
6.4 HEMI
I would not say that is for everyone.
Just for me.
If anyone is willing to try it though they now have at least one example of success
Hemi395
Cape Cod MA
Just for me.
Very true, I jumped the gun a bit on that[emoji23]
I like RL success stories[emoji16]
MontanaHandyman
Montana
Started using Redline a year ago in 14 1500 5.7 with 65k miles. Slowly developed a ticking which got progressively louder. Thank goodness it was the manifolds! Had them taken care of, and now my engine is so stinkin' quiet I accidently turned the key to start it when it was already running...thank goodness the system prevents the starter from engaging.
I often wonder if the few people that redline doesn't kill the tick of have mani bolts as the issue.
U&A
2016 3500 SRW
6.4 HEMI
Sounds like you need a solo performance muffler delete kit from @Nick@GotExhaust
[emoji16][emoji16][emoji16]
Travis8352
Houghton michigan
ive recomended redline to a few guys with ticking hemis and they all say the same thing "Oil cant fix a design flaw" O direct them here but nothing. Oh well not my truck i guess
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I haven’t been keeping up as I should been busy with life. I did want to share I got Shell Gas Truck 5w-20 full syn at Walmart on clearance for $10 a 5 Qt jug so I bought the last three. I’ll use them in my wife’s T&C. l then found a random quart of PP 10w-30 for $1.66 they only had one left. If you are not brand specific you may want to get some.
HEMIMANN
Minneapolis, MN
Maybe they don't want to read 4,000 pages of analysis and testimonial? :anitoof:
tidefan1967
Summerville, South Carolina
Well I don’t know why not, it’s actually the heart and soul of the forum. This is actually the one thread where you’re pretty much safe from dumb questions and a logical approach seems to prevail most of the time.
