NJ4X4
What does the Android Auto look like if it's not built in.....connected with a dongle?
Good question but I doubt it. I know BT OBD adapters don't work.Not sure if this has ever been asked on this post.... If I ever get one of these T-style radios to work, I'd like to get the new Pedal Commander that works with blue tooth. Does anyone with one of these t-style radios use the blue tooth Pedal Commander with it? I'm thinking I could use the Pedal Commander through an app on the t-style radio?
Have you tried to connect to it via Bluetooth in the radio?I have both and love the pedal commander , no real reason to use with the radio because u can just adjust the settings right on the commander easier then the app . Would be available however if you wanted though.
OK....I'm just not crazy about the look of the commander....the yellow doesn't work with my interior at all. I would rather mount it where I don't see it.....and control it on the radio screen.
I was gonna say the same. I think I've changed it maybe twice since I got mine (non-BT version).You could always change with your phone, I haven’t changed my settings since I found the one I normally use all the time. Would be rare to need to change on the fly in my use case anyway
OK.... for some reason, I was under the impression it needed to be turned on / set each time you start the truck.
I'm told that the latest firmware release for PX6/Android 8.1 radios allows one to alter the order and default app opened for the icons in the top menu bar.
That should make a few of you happy (without root).
I never did receive any possible fix from Phoenix for my radio going to the back-up camera and staying there when starting it up. I did notice something else about it though....and wondered if this info might help someone here to figure out what's going on with it... So it goes to the back-up camera page....and will stay there for around 5 minutes before going to the home page. But, I noticed if I go to turn the truck off, the instant you turn the key toward the shut off position, it immediately will go to the "android" word screen and then will start up correctly. Does that info help anyone figure out what's going on with it? Another strange thing is it does this every morning....but usually later in the day it boots up normally. Not always, but usually.
Thanks!
