jon martin
So where does the unit get the outside temperature reading from. It never matches what my truck says. So times it's a difference of 2-3 degrees and sometimes 15 degree difference
Same thing different sellers. Some have modified the firmware slightly and Linkswell appears to have modified the software slightly and wired in an external microphone.So I see a few different places selling these. Are they different brands or all the same thing just relabeled? Is there one brand or distributor better than the others?
I'll give it a try today and let you know. The extra harness is for higher trims...I don't get Temp display either (7.1 fastboot unit from Rhino Radios).
Does anyone else have a problem with defrost not working correctly? It says it's on and it blows out but I don't think my AC unit is kicking in to dry out the air. Too cold to test ac here. I had an extra plug that came with unit but no harness to connect it to. I don't have auto air controls so figured it was for that. I plugged in both harness plugs that went to my old Temp controls. I was driving home from airport and notice my windows would be way more foggy than any time in the past. Had to put it on high and still had some fog on side windows and top of windshield. Back window completely Co overed no matter what. Any ideas?
In my opinion, Linkswell is way over priced but you'll likely get the best support from them.Thank you. So is linkswell or phoenix the preferred "brand"? External mic is just for bluetooth calling?
Phoenix Android is priced ok, but support is not as good and requires a lot of customer persistence to get a resolution but they do typically always respond (eventually).
The external mic is for improved Bluetooth calling but can easily be done by the customer if they have some rudimentary technical skill.
Is there a problem with them? Aren't the trailer brakes controlled by a separate module under the radio bezel?Have there been any updates regarding this radio and air Suspension on trailer brakes
I see, I don't have either of those options so I can't answer but there are several folks on here using these radios that I believe have those options so maybe they can chime in...they may be in a different time zone so they won't see this for a while possibly.I wanted to check before I buy the unit. Yes the trailer brakes are controlled separately but there's a menu option in the radio where you assign the type of trailer brake. If it'll stay set to that then that's okay. For the air suspension I need to be able to turn it off when jacking up the car
Your #1, what do you mean you saw how to use the factory ones? Do you mean using the OEM microphone?I ordered one from Phoenix but just returned it. They would never respond to my tickets and just close them out.
#1 Mic sucked, Yes I saw how to use the factory ones.
#2 The factory reverse camera would not come on, "No signal"
#3 The temp setting was too coarse , I would have to max it one way or the other, then adjust it after the temp felt right in the truck. Set at 70° and the air would be 60°
#4 The door open indicator. My door was closed on the dashboard but the radio, I needed to open and close the door at least 2-3 times to get it off the radio screen.
#5 The USB media would play ONCE. then there was no audio if I changed sources. I would need to do a complete reset to use it ONCE again.
#6 The Nav could not use the vehicle as UP. it would only use true north for travel. ( I like my vehicle showing "up" )
This was ordered a month ago and returned last week. I guess Ill wait until there is more updates to them.
I'm very interested in what you are referring too. Can you provide details on getting the OEM microphone working?Yes, OEM mic,
They never answered the questions. The tickets were closed and deleted. I did a search and my topic did not show up anywhere.
Darn... thanks. I thought maybe you were referring to something else.Referencing post #4 in this thread.
