The HP game
danielmid
Southeast WI
2015 Sport 4x4
Recorded earlier today. Winds up nicely but 2wd it steps out on the 1-2 shift.
This is just the canned tune still or is this the Hemifever tune?
ThunderMug95
ThunderMug95
North Prince George, VA
Anybody know where the AGS derives its signal from? I can’t remember if its PCM or BCM. I cheated it years ago when I installed the vararam…just removed the slats except for the very top slat and very bottom slat so it wouldn't throw codes. I cant remember if it was something AlphaOBD could delete. I have Alpha, just haven’t used it in several years and not certain the Android phone I have it on will even power up. Oooff!
danielmid
Southeast WI
2015 Sport 4x4
Is that not working? I used a screw kit and pulled the slats totally out but your method should be working fine. As far as I know Alfa can't touch them, and I haven't read about any tuner dealing with them either.
ThunderMug95
ThunderMug95
Screw kit? Do tell…
I assume theyre working, no codes, but theres only the 2 slats left in mine, just the bare minimum to make the brain think they are working…
danielmid
Southeast WI
2015 Sport 4x4
Screw kit? Do tell…
If you don't have codes why are you wanting to change it up?
I used this kit:
ppine
Forester
Nevada
6.7 liter diesel
"Upping your game" seems to have become a game.
There is a whole industry of after market upgrades.
I like my truck in stock configuration and I am going to run that way at least until it is out of warranty.
ThunderMug95
ThunderMug95
Fair point. Im out of warranty now, but when this journey started I was in-warranty and behaved accordingly
Ludville1
5.7 Hemi Sport Crew
Just did some data logging for HF. Just like everyone says, canned tunes are better than stock, but not anywhere close to this Hemifever tune. I had to do a WOT 0-75 pull. HOLY CRAP. I’m still smiling and my face hurts.
I remember doing the data logging 0-75 WOT pull for Hemifever...took off like a rocket, the wife and I were shocked! Sean said "everything looks good...if you are happy with it, run it!" And I have been ever since. He also said to continue using that gas station...local Shell 93.
ThunderMug95
ThunderMug95
Finally got the logs to Sean. Ran 3 sets as prescribed. Its impressive. With the Moes 87mm TB, Vararam and the MF exhaust, its pretty smooth. I have 3 things to do in 2024.
1. Long tubes w/cats
2. V6 efan & Tstat
3. TruTrac for the rear.
Eh, going to need new tires as well…
Noob2Trucks
I was running close to your planned setup before the cam/stall
Vararam, stock tb, V6 fan/tstat, HP tuners and custom tune, Mopar LSD, 3.92 gear, arh 1 3/4 headers w/cats, qtp cutout.
Green was pre-cam, red after.
ThunderMug95
ThunderMug95
Thats awesome info, thank you. Anybody have a baseline fir a stick 5.7?
Also, the 6.4 manifold…does it need to be off of a truck? Mist Ive seen have the intake TB angled to the drivers side…
Reticle918
