Throttle number setup at inTune
hog4oc
What's the number you setup the throttle at your inTune?
I did 4.5 - made improvement, then setup at 9 which is too sensitive, so I dropped to 6 this morning and will drive to work in couple of mins.
will keep you update.
hog
Nutshell
Hmmm, I'd like to know too. Which tune are you running?
Arctic-Rodz
RGV, TX
6.7L Cummins
you talking about the the throttle booster?
popcenator
Omaha, NE
I'm currently at 10% and like it. If you're taking about the throttle booster that is.
on the move..
ob1sw4n
12-15% here I believe, pretty happy with it there, haven't tried anything higher.
Jerseymike
Im at 14%. Its pretty jumpy. I let my buddy drive it and he kept snapping my head back.:headbang:
Bully's Performance
this happens to me when I let other people drive too (happened in the truck and the chally) I have mine set at 20%
BlownGP
Houston/Baton Rouge
Quick question since were talking about intunes.
Lets say I load the Diablo 87 tune and then I modfiy it. Install it.
How do I get that exact same modified tune if I put it back to stock for a dealer visit?
H
hog4oc
i changed it to 20
I changed the throttle booster number to 20 (i think it is max), seems working fine.
Also replaced the factory muffler to Magnaflow muffler (24) and love the sound (quite).
Hog
EdmontonSS
Edmonton, AB, Canada
I run mine at 20% as well, and you get used to rolling off the line so its not too jumpy every time the light turns green. But its nice that you can hammer on it and you dont have to wait for the damn throttle wire.
As for keeping the changed 87 tune when you return to stock, I believe my InTune comes with the "save last tune" feature when you go changing the tune out, so basically if you are on your changed 87 tune and you select to tune it back to stock... there should be an option to save the current tune in a file (the 87 tune), and when you are done at the dealership, just go back into your tune listings and find the last one. Unless they changed it recently, that is how I understood it to work.
